Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Adjusting the idle on a Predator?
    Hello all.
    I picked up a new 212cc Predator engine recently to run in an old mini-bike of mine.
    I loosened the throttle arm nut, and hooked up a throttle, but I can't seem to get the dumb thing to idle.
    The engine engages the clutch even when idling, and it idles quite high. I can't seem to find an adjustment screw anywhere.
    Am I missing something? Is there an idle stop / adjustment on these engines?
  2. #2
    Senior Member
    Join Date
    Dec 2010
    Location
    USA
    Posts
    400
    Rides
    looking from the back side of the engine, find the carb. now looking on the top of the carb find the throttle valve. there will be a screw that when turned in, highers the idle, and turned out lowers the idle. you need to pop the cover off the screw (weird) and use a phillips head screwdriver to loosen it. hopefully that solves the problem.
    if you cant figure it out, ill go snap a pic for you
  3. #3
    cjtmini's Avatar
    Join Date
    Feb 2008
    Location
    westland mi.
    Posts
    563
    Rides
    it looks like this
  4. #4
    Junior Member Justin1er's Avatar
    Join Date
    Mar 2013
    Location
    philadelphia
    Posts
    Rides
    I've been trying to figure this out glad you had the pictures. So I've turned the screw and the idle does not change it still idles at 5mph.
  5. #5
    Junior Member
    Join Date
    Apr 2013
    Location
    st pete
    Posts
    Rides
    Yea I've had the same exact problem on my engine and I did all the steps checked the throttle cable twice lowered the adjust screw nothing helps still idles at a high speed
  6. #6
    Senior Member SIMPLEARKANSAN's Avatar
    Join Date
    Feb 2013
    Location
    Arkansas
    Posts
    571
    Rides
    Did anyone ever figure this problem out? I'm now experiencing the same thing.
  7. #7
    Junior Member
    Join Date
    Jul 2013
    Location
    Sugar Hill
    Posts
    Rides
    It is possible I'm having the same issue.
    POST LINK
  8. #8
    Member
    Join Date
    Jun 2013
    Location
    Bakersfield, CA
    Posts
    Rides
    I think I did. The governor arm needs a spring to close the throttle butterfly. I just bought a predator and I noticed it wasn't opening and closing the carb butterfly all the way so I messed with the governor set up and now it closes and opens all the way
  9. #9
    Member
    Join Date
    Jun 2013
    Location
    Bakersfield, CA
    Posts
    Rides
    Join Date
    Feb 2013
    Location
    Arkansas
    Posts
    571
    Rides
    I was wondering and extra spring would help. I noticed my butterfly wasn't closing too. What happened to the spring that surrounded the governor linkage and attached to the butterfly? Thanks for the pic.
Similar Threads
  1. Adjusting idle DOWN on greyhound 6.5 clone
    By dill_hole in forum Honda / Clone / Predator
    Last Post: 04-19-2014, 06:55 PM
  2. 3hp Valve Adjusting
    By weldkingoc in forum Briggs & Stratton
    Last Post: 02-19-2012, 08:07 AM
  3. Predator 212cc won't just idle. please help.
    By rtowns in forum Honda / Clone / Predator
    Last Post: 10-29-2011, 07:26 PM
  4. ? on adjusting governer
    By FASTANDLOWAVENGE in forum Baja Mini Bikes
    Last Post: 05-13-2009, 09:48 PM
  5. ? on adjusting governer
    Last Post: 05-11-2009, 09:47 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Banner
