Results 1 to 2 of 2
  1. #1
    Junior Member
    Join Date
    Nov 2011
    Aurora, MO
    420 charging/lighting coil
    I've been trying to find affordable parts to upgrade my electrical system to make it capable of running lights and keep the battery charged. Prices I've found so far put the cost of the stator coil, flywheel, and rectifier/regulator at $430. That's more than $100 more than I spent on the engine new. The engine came with electric start and a 3 amp charging system. Do I need to replace the current flywheel? Also, does anyone know where I can find cheaper (alot cheaper) parts to accomplish this?
  2. #2
    Senior Member Dave_In_Florida's Avatar
    Join Date
    Aug 2009
    Tampa Florida
    From my research, the different amp charging systems just have different stators (more spots for windings to get passed by the flywheel magnets). Say your 3 amp system has 2 spots on the stator, the 6 amp would have 4 spots. So I think you would just need to buy the stator, and use the rest of your parts.
Similar Threads
  1. Clone With charging coil
    By balljoint in forum Honda / Clone / Predator
    Last Post: 06-30-2015, 01:14 PM
  2. Charging coil question re: baja warrior
    By Kierw in forum Engines and Modifications
    Last Post: 12-23-2011, 09:03 AM
  3. charging coil?
    By GraveBugger in forum Briggs & Stratton
    Last Post: 09-09-2011, 09:33 PM
  4. charging coil off jian dong work on greyhound?
    By adclax1 in forum Honda / Clone / Predator
    Last Post: 06-20-2011, 05:50 PM
  5. Tecumseh H-Block Charging Coil
    By MarksA-C in forum WANTED
    Last Post: 12-19-2010, 05:58 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
