I was riding my mini when i suddenly lost power and when i pulled into my garage i saw my carb manifold bolts on the head were loose. took engine off cause I needed to do an oil change anyway, when i finished reassembly of the carb bolts (tightened down), replaced the gasket on the surface where the manifold meets the head, and now it still wont start
it seems like its starving for fuel but I opened my carburetor up and it is completely clean, no blockages and the float height is to spec. what could be the issue here because at the moment i am at a loss on why it will not start without starting fluid and even then won't stay running
