Nick Felt's latest activity
N
Nick Felt
replied to the thread
HM80 only runs with choke on
Thanks
Apr 23, 2024
N
Nick Felt
thanks for the help, the best i've got it to run and still idle is idle mixture screw at 1.5 out and the high speed at 2.25 out, i tried...
Apr 23, 2024
N
Nick Felt
Thanks, got it to idle nice. It's running real rich right now and has a surging at about 1/3 throttle. I tried turning the main jet in...
Apr 22, 2024
N
Nick Felt
Yes I did, pulled it completely apart and cleaned it all. The two holes for the idle circuit one is larger than the other, im not sure...
Apr 19, 2024
N
Nick Felt
All thanks for the advice, I got the bike to run and idle well. My starting idle mixture screw and main were too low. I'm not sure...
Apr 19, 2024
N
Nick Felt
I did not pull these, never thought to. I'll do that when I reclean everything.
Apr 7, 2024
N
Nick Felt
Thanks, it's not blocked. I'll pull the carb again and do another cleaning on it and see what happens.
Apr 6, 2024
N
Nick Felt
I tried that, it still runs when all the way in.
Apr 6, 2024
N
Nick Felt
I took it apart and cleaned it all out. Still about the same, still having the same issue getting the idle set right, it will idle high...
Apr 6, 2024
N
Nick Felt
I got it run ok, it does idle but too high. I'm trying to fine to that, it's either too high or dies. I don't have a way to tell the RPM...
Apr 6, 2024
N
Nick Felt
I'll have to do it. It had a slide carb on it from the previous owner.
Apr 6, 2024
N
Nick Felt
Yes, it was just off in the photo.
Apr 5, 2024
N
Nick Felt
It is OEM
Apr 5, 2024
N
Nick Felt
posted the thread
in
I've been building my Super Bronc. I've got the stock carb and the governor linkage all hooked up. It will start with the choke on...
Apr 5, 2024
N
Nick Felt
Tecumseh 632402 Carb Idle Set Screw and Spring
I found the screw and spring online, here are the part numbers if anyone else needs them 651025 + 630766
Apr 5, 2024
