Found a newer style vertical shaft in the dumpster at work. I was curious to see what had changed since the 70's when I was a kid fixing mowers. There is a lot more plastic, the cam gear, oil pump housing, and a plastic bushing on one end of the cam. Also a real centrifugal compression...
Like Rocky Balboa, I'm stupidly getting back in the ring with a Tec OH60. Decided I'd rebuild from ground up--was an oil burner and I need to clean up the head and exhaust ports. Anyone have any suggestions for cleaning all the carbon build up out without access to a media blaster? I'm a little...
Is a Harbor Freight Predator #69730 a hemi engine?
Does anyone have pictures of the combustion chambers for the various Harbor Freight Predator 212cc engines?
