I was just out cleaning and lubing my chain and wondered what others use for lube.
The last time I lubed it I used the end of a 15 year old can of Honda chain lube. Today I started on what's left of an old can of Maxim chain wax. These were from the days of doing it to the 520 dirt bike...
Hi, first time posting here but been doing lots of reading. I recently put a HF 212cc engine on a Doodlebug and the clutch has the sprocket facing inboard (facing the engine). How do I get to the bushing to oil it? I can't even see the space in the clip.
So I was not sure were to post this but two subjects into one.
• Really cool tool that I use.
• Chain lube juice recipe
First is the tool which is a non-aerosol sprayer which means you can put in whatever lube or penetrating oil in it and use shop air to charge it. BTW I have had this sprayer...
I'm just looking around the Oldmibibikes.com website when I run across this Max-Lube clutch. What a great invention! Completely new to me.I've never seen any info posted about them on this web site at least. I remember there was one clutch were you had to drill a hole down the length of the...
wondering if this will work for the comet tav clutches?
Birchwood Casey Moly Lube Dry Film Lube 4oz Aer 40131 - eBay (item 220582582105 end time Feb-25-11 12:04:01 PST)
I was wondering what lubricant would be good for a clutch on a tecumseh h50? It sounds like its grinding and won't run right. I used a little wd40 and that made it run alot better but wore off quickly. Any help would be greatly appreciated. Thanks-Steve
