Hello Everyone,
My Boonie Bikes' Techumseh ohh50 is leaking oil from bottom of crankcase cover on side w PTO.
I changed the oil, and inadvertantly overfilled it...althought the 'dipstick' did not indicate it ? :shrug: I ran the motor, up the street and back, then realized i'd over added...
I'm selling off an 5HP OHV Tecumseh I was using on my Bonanza. Runs awesome. Has your standard 3/4" keyed output shaft with square bolt pattern around it. Tins are in nice shape and the pullstart works perfect. Really nice for a basic reliable runner.
Only issue is that I "modified" (as...
I'm putting this engine back together after water intrusion.
These 2 identical pieces fell out and I have no idea what they're from. I checked te recoil, but that's intact. Please help as I'm actively putting this engine back together before my son gets home I'm less than 2 hours.
Thanks...
I have an OHH50 and it will crank but when I press the throttle it trys to shut off. The tank is getting air but I dont have an air filter to go on my carb. Help?
Guys,
I am a novice at this so bear with me. My son has a GoKart with an OHH50 on it that we bought very used. The throttle linkage has been rigged to work but the lever that attaches to the governor will no longer stay attached. I am ordering a new lever clamp but my question arises after...
I looking for a carb repair-rebuild kit for a ohh50. Anyone know what kit number i need? The carb is the one with the red primer ball. Needle-seat leaking on it.
Clean Power Sports OHH50 engine Model OHH50 68024F Family 172U1G1RB DOM 8030 3/4 shaft. I purchased a Bonanza 1100 and this engine was on it, I like flat head engines of the era of the mini so im selling it.
The history I got was the mini was painted a new seat installed a new engine and...
I was gathering the parts together to reassemble my HS50 and somewhere I misplaced one of my Circlips for the piston, all the others I have from various brands of engines are too big or too small so Tec must have thier own special size...
If anyone has one of these clips let me know what you...
so i was out riding my mini in the street like last night for about 30 min.. i was riding it full throttle most of the time..then went to put some more fuel in..the motor was still warm... so i go to pull it and it its all of a sudden was a pain in my ass to start...like the back pressure went...
