Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Member Zach's Avatar
    Join Date
    Jan 2009
    Posts
    95
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Lawn Mower engine
    I have a Craftsman 3.5 lawn mower engine and I was wondering If I could possibly use it on a mini bike. It has a vertical shaft (which I was gonna cut off), and it has a horizontal shaft running on the side with a sprocket and chain. I was wondering if that would work if I cut the shaft flush? It's came from a self propel unit.
    Thanks,
    Zach
  2. #2
    Join Date
    Jan 2009
    Posts
    95
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    also the sprocket has set screws holding it on. So it can be removed and switched for a clutch. It's a small shaft tho like the size of a sharpie marker.
  3. #3
    Senior Member mardyn's Avatar
    Join Date
    Nov 2008
    Location
    Beautiful East Texas
    Posts
    497
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Not sure, but I think the aux shaft runs at a significant reduction from the main shaft RPM... maybe as much as half speed.
    Save yourself some time and trouble, just get a horizontal shaft engine to stat with.
    mardyn
  4. #4
    Join Date
    Jan 2009
    Posts
    95
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    no it spins fast one revolution for every one the normal shaft does. + I own it already so that's a plus. It's already running a #35 chain
  5. #5
    Join Date
    Nov 2008
    Location
    Posts
    497
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Must be different from the ones I've seen... the aux shaft was driven off the cam gear which turn at 1/2 speed from the c/s rpm.
    Good Luck
    mardyn
  6. #6
    Senior Member
    Join Date
    May 2008
    Location
    Sioux City, Iowa
    Posts
    1,321
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    just dump the idea, and save yourself the pain. Lots have tried, and I have never seen a success.
  7. #7
    Tom S.'s Avatar
    Join Date
    Feb 2008
    Location
    Hillsboro, Ore.
    Posts
    4,930
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Zach View Post
    Thanks,
    Zach
    I'd like to see a picture of that, please, if you're able.
  8. #8
    Junior Member
    Join Date
    Jan 2009
    Location
    Minneapolis, MN
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Easier just to take the motor and rotate it 90 degrees and make a new intake for the carb to make it live in the correct orientation.
  9. #9
    Banned Strigoi's Avatar
    Join Date
    Mar 2008
    Location
    Martinez, CA
    Posts
    10,058
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by four-thirteen View Post
    are you serious?
    that won't work.
  10. #10
    Senior Member recoil's Avatar
    Join Date
    Dec 2008
    Location
    Australia
    Posts
    113
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Strigoi View Post
    are you serious?
    that won't work.
    If its a 4 stroke yes forget it you cant flip the motor because the sump needs oil, but if its a 2 stroke it shouldn't be much problem at all. As stated all you need to do it rotate the carby. Here if a picture of my bike engine that were produced as vertical shaft lawn mower engines.
Similar Threads
  1. Cast iron lawn mower engine on a minibike?
    By Ruello in forum Engines and Modifications
    Last Post: 10-02-2010, 11:11 AM
  2. Honda lawn mower
    By Six Gun in forum Off Topic Discussion
    Last Post: 06-03-2009, 01:22 AM
  3. Lawn Mower or Leaf Blower Engine
    By perzianrider in forum Baja Mini Bikes
    Last Post: 10-21-2008, 07:57 PM
  4. lawn mower engine wont crank
    By Bigtank05 in forum Off Topic Discussion
    Last Post: 09-02-2008, 10:25 PM
  5. Lawn mower.
    By TheRedNova in forum Go Karts
    Last Post: 11-22-2007, 09:08 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
