Follow us on...
User Tag List
Thanks Thanks:  7
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
  1. #11
    capguncowboy's Avatar
    Join Date
    Apr 2014
    Location
    Bluff City, TN
    Posts
    5,179
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Havasu Dave View Post
    One last consideration on gas tanks. You will be taping the tank off somewhere at the cap threads, lower. When you go for the application of clear, tape the cap above the line you taped for the base, so the clear overlaps it. This will prevent fuel from wicking into the base, creeping down the neck and causing bubbles in the paint.
    Thanks Dave, that's an excellent tip.
    I'm not afraid of death. I'm afraid of dying. I want to go peacefully in my sleep like my father did -- not like his screaming passengers
  2. Thanks Havasu Dave thanked for this post
  3. #12
    Member RustyRedneck's Avatar
    Join Date
    Dec 2016
    Location
    Huron SD
    Posts
    69
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I've heard it is also important to do everything with the same brand of paint from primer to clear. Is it as critical with a rattle can or more so?
  4. #13
    Havasu Dave's Avatar
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    7,289
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by RustyRedneck View Post
    No. Automotive paints: These companies are in business to sell their products, so of course they will post dire warnings about mixing products. When you start getting in to your multi-stage, high end paint jobs, then yes, it "could" matter, but these days, even candies are urethane or acrylic, so it's not such a big deal.
    A friend of mine was the owner of a successful body and paint shop in SoCal for several decades. (He gave the business to his son who now does high end car restorations) He, and those guys use one type of primer, another type of base, and another type of clear.
    Hardware store spray paints: You will get varying degrees of color differences between different MFGR's products, even though they are labeled the same. So this can be a problem, and a rule of thumb is to try and stick with the same MFGR, although I don't always. You also don't want to put lacquer over enamel, including primers.
    But as far as the original post concerning the urethane clears, they will go over anything that isn't petroleum. Rust, dust, bugs, no problem. Another tip you'll read on any MFGR of clear urethane is to scuff up "cured" base coats with 800-1000 grit. That is what they "recommend," and they say it because they don't want a poor paint job to be "their" problem.
    Clear over Cured Base Coats: In reality, I've gone several weeks between painting a Tecumseh engine with black spray paint from ACE, blew off the dust with my air chuck, and squirted urethane clear over it with no problems.
    If it makes you feel better, you can certainly scuff it up and blow it off, and tack rag it. However if you used some fancy rattle can (or even automotive base) with pearl or flakes, the sand paper will knock off the dyed bits off the pearl/flake leaving it it's original white plastic color. Might be micron-sized, but it will show up in the work after the clear is shot. Solid colors like white, or black, no problem. But instead of scuffing it an clearing it, scuff it and shoot another coat of the base coat, then clear it within 30 minutes.
  5. Thanks FOMOGO thanked for this post
  6. #14
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    2,855
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The OP never answered my question if the tank is metal or plastic. Very good advice from above ^^^, however, only if the tank is METAL. If it is a PLASTIC tank all bets are off as paint will peel off of a plastic tank as the gas fumes will eventually permeate through the plastic unless you coat the inside with a product like Caswells.
    Michael
  7. #15
    Junior Member
    Join Date
    Oct 2016
    Location
    North Carolina
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The tank I need to paint is plastic and a very ugly grey.
  8. #16
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    7,289
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by bed9fc View Post
    Well that changes everything. So my 1000 word essay was a waste. LOL! Yes, as Michael says you should coat the inside with Caswell's, or at least that is what I have heard. Conversely, you could do your primer with a catalyzed version out of a spray gun.
    There was a guy on here a couple of years ago, a plastics expert or in that field. He spoke about using an open flame on plastic tanks prior to painting. I think Markus has done that too. I don't know squat about this, so I'm out. :) @markus
  9. #17
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    2,855
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Gee, that sure would have been nice to know!! I strongly suspected it was and that is exactly WHY I asked. A lot of wasted time and effort by our knowledgable and caring members with their replies trying to help. Personally, I am done with this guy as he STILL has not even had the courtesy to thank anyone for their replies...
    Michael
  10. #18
    Junior Member
    Join Date
    Oct 2016
    Location
    North Carolina
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    First off, I am not sure where the hostility came from. Thanks everyone for the input. I have often had questions about urethane coatings on plastic as well as metal and more importantly the prep work required to get not a good finish, but great finish. The responses listed by all are greatly appreciated and look forward to suggestions in the future.
    I am greatly intrigued by the idea that I don’t need to mix up a two part clear coat and spray via the HPLV and use an easier method to apply a sturdy coating.
    Brian
  11. #19
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    2,460
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    When I painted my rupp engine I used summit single stage white which is impervious to gas (urethane) My tank was plastic and I first used a adhesion promotor and epoxy primer, came out great but now after 9 months I see a bubble in the paint at least a inch around. I need to order more dragon blood or make a metal tank.
    Ole
  12. #20
    Dr. Shop Teacher's Avatar
    Join Date
    Feb 2015
    Location
    Falmouth, Virginia
    Posts
    2,483
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Personally, I learned my lesson with a plastic tank. I'd avoid it if I could. If it's white, some folks have suggested Beauty Shop hydrogen peroxide--google it within the forum and I think several tips will pop up. I haven't tried Caswells or Red Coat on a plastic tank, stands to reason it'll work if it adheres to the plastic.
    An aside, I also learned another lesson with epoxies (i.e., JB Weld) and <<steel fuel tanks>>--the gas ate the epoxy--and I hadn't learned about silver soldering, yet.
    Wilderness~Copperhead~Trail Bike
Similar Threads
  1. Eastwood 2K Urethane on Sale
    By Dr. Shop Teacher in forum Shop Tools
    Last Post: 07-10-2015, 12:37 AM
  2. What Is The Best Clearcoat?
    By Yellowhand in forum Mini Bike Discussion
    Last Post: 11-26-2008, 04:01 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
