Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Senior Member vintage33's Avatar
    Join Date
    Nov 2009
    Location
    kannapolis
    Posts
    139
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Angry need help on my 5hp clutch removal
    i need help removing a centrifugal clutch of my 5hp its the new briggs not the overhead valve one it has a key whole in the middle of the shaft that has a screw going threw it with washers. I took that off then i couldnt take the clutch off. I used alot of wd-40 but that didnt work. I used a flat head screw driver and a hammer to try to remove it but still to hard i dont want to mess it up because im going to have to use it again need help if someone get send me a video or some pictures on how to remove it or just giving me some steps on how to do it thanks
  2. #2
    Senior Member mybiz's Avatar
    Join Date
    Apr 2009
    Location
    In the Boonies of Winfield, KS
    Posts
    4,976
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Did you remove both set screws?? some have 1 some have two read this you'll have to scroll down.
    Service Tips for Go Karts and Mini Bikes
  3. #3
    Senior Member Oldsalt's Avatar
    Join Date
    Apr 2007
    Location
    Walla Walla WA
    Posts
    3,801
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hammering a flat head screw driver between the clutch and the aluminum crankcase will often result in a distorted case. I'd advise that whatever is done to remember that the clutch is not the most expensive item. Engines generally are harder to come by.
  4. #4
    Join Date
    Nov 2009
    Location
    kannapolis
    Posts
    139
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    **mybiz**
    it doesnt have any set screws atleast i dont think so if it did i dont know where it would be
  5. #5
    Senior Member 71dodge's Avatar
    Join Date
    Dec 2008
    Location
    inverness florida
    Posts
    3,101
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    there on the side of the clutch it has to have them if it isnt coming off or its rusted on there. try using a pickle fork
  6. #6
    Join Date
    Nov 2009
    Location
    kannapolis
    Posts
    139
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    i couldnt see the screws not sure it has it
  7. #7
    Join Date
    Nov 2009
    Location
    kannapolis
    Posts
    139
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    ok i took the drum off but i cant get the rest off still need help
  8. #8
    Senior Member
    Join Date
    Aug 2007
    Location
    Illinios
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If you took the drum off, then the screws you are looking for will be on the engine side of the clutch. If there are no screws then there should be holes where at least one screw should go. When you are absolutely sure the screw or screws are out, get you some pb blaster penetrating oil, because wd40 sucks, I know, I have used both.
  9. #9
    Randy's Avatar
    Join Date
    Jul 2008
    Location
    Mechanicsburg, Pa
    Posts
    5,069
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    It must have been mounted outboard. They can be horrible! I just had a Kart engine like that and ended up cutting the clutch hub from the crank. Even then I had to peel it off with a hammer and chisel. I should have taken a photo of the aftermath. If people took 5 minutes with a file and emery cloth prior to installation we wouldn't have these problems.
  10. #10
    Senior Member Rockwall's Avatar
    Join Date
    May 2009
    Location
    Texas
    Posts
    1,911
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hold up
    Stop what your doing and take some pics of the situation !! ... You can trash a block and crank easily when your getting frustrated (I know first hand) ... Slow down ... Take some pics ... If you need help loading pics pm me ...
Similar Threads
  1. Clutch removal how to
    By loveoftiki in forum Engines and Modifications
    Last Post: 07-01-2010, 02:45 PM
  2. Clutch removal
    By Kornwalus in forum Engines and Modifications
    Last Post: 06-28-2010, 11:42 AM
  3. Powell clutch removal
    By george3 in forum Mini Bike Discussion
    Last Post: 07-11-2009, 07:52 PM
  4. Clutch removal issues
    By John ONeal in forum Baja Mini Bikes
    Last Post: 06-23-2009, 05:58 PM
  5. Clutch Removal!!
    By 07D675 in forum Mini Bike Discussion
    Last Post: 02-14-2008, 09:15 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
