Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 3 of 3
Thread: Fuel Pump
  1. #1
    Senior Member Rclinetx's Avatar
    Join Date
    Oct 2011
    Location
    East Texas
    Posts
    230
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Fuel Pump
    Question,
    What are the befits of adding a fuel pump even though my tank is above the carb?
    The motor try's to die when I come to a stop and have to keep giving it just a little gas.
  2. #2
    Senior Member metalhead100's Avatar
    Join Date
    Mar 2012
    Location
    USA,Paragon,Indiana
    Posts
    866
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    check your idle jet and carb passages and make sure you have NOT blocked the little holes in the carb where the filter mounts....one is for the idle circuit in the carb...filter adapter can block them sometimes....
    .....it should be fine....my tank is mounted like yours and mine runs fine....
    Know how to check it?....Here is a PDF file of the carb checklist from honda
    http://www.google.com/url?sa=t&rct=j...6TIpQm1ddwfIJA
  3. #3
    Richard Trotter's Avatar
    Join Date
    Jun 2008
    Location
    Spanish Fork,Utah
    Posts
    1,943
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Some in-line fuel filters will restrict flow on a gravity fed system. A fuel pump would insure there is gas going to motor.
Similar Threads
  1. Mikuni DF-62 fuel pump new drag pump $40
    By JOHN R GANG in forum Mini Bike Parts
    Last Post: 02-28-2012, 09:35 AM
  2. can you use a fuel pump as an oil pump/antifreeze pump?
    By Modding_out in forum Engines and Modifications
    Last Post: 10-27-2010, 12:36 PM
  3. Walbro fuel pump-no fuel delivery
    By mmisterbungl in forum Engines and Modifications
    Last Post: 10-17-2010, 08:51 PM
  4. Fuel filters, pump and non pump?
    By DreyeIce in forum Engines and Modifications
    Last Post: 07-26-2010, 11:56 AM
  5. need fuel pump
    By micro bill 7 in forum WANTED
    Last Post: 03-18-2009, 10:04 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
