Register Members List Calendar Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Project Logs
Project Logs This section is for write-ups, how-to's and project logs.
ASK QUESTIONS IN GENERAL MINI BIKE TALK - IRRELEVANT THREADS WILL BE DELETED
Reply
Thread Tools Display Modes
Old 04-11-2009, 01:01 AM   #21 (permalink)
delray's Avatar
i was going to prefit the torque converter(tav-2),but the aluminum backing won't fit at all i had the bike mock up with a bolt on steel jackshaft unit.
so i new that would fit ok and all that thing is a old style torque converter unit that has a steel backing plate and not a aluminum unit made into a jackshaft unit.
there is just to much casting material on the aluminum unit to make it fit,
when swaping out the parts from the aluminum unit to the steel unit there was couple things i had to do. i had to make sure i use the shaft out of the aluminum unit(longer)
also had to change out the #35 C sprocket to a #41 C sprocket
bolted up and it fits with no problems
and lots of leg room too....
delray is offline   Reply With Quote
Old 04-11-2009, 01:47 AM   #22 (permalink)
Senior Member
zipseattle's Avatar
The older TAV unit has a much sturdier cover - I'd say the change was for the good.
zipseattle is offline   Reply With Quote
Old 04-11-2009, 08:09 AM   #23 (permalink)
French model
jimh's Avatar
That's gonna be a nice cruiser. They ride pretty good stock, but the rear suspension will be even better. The 5hp Briggs and TAV should pull it around better than the original. I wish you'd hurry up though. You're almost as slow as me.
jimh is offline   Reply With Quote
Old 04-11-2009, 08:42 AM   #24 (permalink)
delray's Avatar
yes jimh kind of slow. with my work and a 15 month old son every morning before work it's kind of slow.
5hp should do real good. i have had real good luck in the pass with 5hp briggslots of torque.......
Old 04-18-2009, 12:11 AM   #25 (permalink)
delray's Avatar
i desided to drill two small holes threw the bolts on each side and install a cotter pin so the bolts don't walk them self's out
Old 04-18-2009, 12:37 AM   #26 (permalink)
delray's Avatar
when i purchase the bike it came without any brake parts. only the arm and spring return
i need to fab something up,so this is what i came up with today on my day off from work. all my brake parts i use where just from some nut and bolts i had laying around(more free bee's and just my time)
just and cast the original spring return breaks or gets real weak. i made it so i can install a new spring over the cable, between the brake arm and cable support bracket.
if the original spring breaks ? it's not like i can run to the hardware and find the samething. so now i have the option of going with something else
at the hardware i have the option of getting stronger or weaker spring and different spring lenths............
Old 04-18-2009, 01:44 PM   #27 (permalink)
Randy's Avatar
That's looking real nice. I like what you did with your cable mount/barrel end. Did you thread the pipe ends where you attached the swing arm? Or is there a insert in them?
Never mind, I went back through and seen where you welded nuts inside the tubing.
Randy is offline   Reply With Quote
Old 04-19-2009, 12:16 AM   #28 (permalink)
delray's Avatar
yes randy,i drilled the holes for the cotter pins right through the nut.
Old 04-19-2009, 12:45 AM   #29 (permalink)
delray's Avatar
yesterday i was at a local retail store picking up some oil and oil filter for my car and stumbled across some trailer lights. i found a real cool little led clearance marker light that will work real nice for my project and not take up to much room for mounting it on the bike. i plan on running lights on the bike so my nephew can ride at night. all the lights will be powered by a battery only,so everything will be leds. with leds he can run hours and hours with out draining the battery down.
fab up a small bracket for the light to mount on to.
i found a real nice spot under the seat to mount the bracket()
the package had a web site on it. i had to check it out
it looks like they have couple other cool lights that are powered by leds
Peterson Manufacturing Company
light was under $8...................
Old 04-20-2009, 05:43 AM   #30 (permalink)
george3's Avatar
how about pics. of the whole bike without the seat?
george3 is online now   Reply With Quote
Reply
Lower Navigation
Tags
build, project, rear, springs
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
NZ Tru-test project build. kiwiandy Project Logs 33 09-11-2011 07:56 AM
rear shock springs Joe48 Mini Bikes & Parts WANTED 2 11-21-2010 07:01 AM
Project Cat, my first build hot turkey Project Logs 33 10-16-2008 11:15 AM
Project.....M-5....Build Off drheilman Project Logs 36 06-07-2008 12:48 AM
70 cat rear springs 1badgixxer3555 General MiniBike Talk 12 11-01-2007 08:01 AM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2 Copyright 2006-2011 OldMiniBikes.com / OMB Group LLC
no new posts
