Register FAQ Members List Calendar Mini Bike Parts Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Project Logs
Project Logs This section is for write-ups, how-to's and project logs.
ASK QUESTIONS IN GENERAL MINI BIKE TALK - IRRELEVANT THREADS WILL BE DELETED
Reply
Thread Tools Display Modes
Old 02-21-2010, 01:16 AM   #111 (permalink)
Yellowhand's Avatar
Boring a sprocket to fit the Sensation hub...
The plate for my lathe didn't have quite the slot distance I needed for the sprocket holes, so I elongated the slots with a carbide rotary file...
Tungsten carbide goes through cast iron like a hot knife through butter, so it took just a couple minutes to modify the plate...
Yellowhand is offline   Reply With Quote
Old 02-21-2010, 01:23 AM   #112 (permalink)
Yellowhand's Avatar
It takes only a minute to change from a chuck to a plate...
I needed to remove about .120" after centering the sprocket and tightening the bolts...
Old 02-21-2010, 01:26 AM   #113 (permalink)
Yellowhand's Avatar
I'll tack the sprocket on, spin it in a lathe to check and adjust for true, then TIG the sprocket directly to the hub...
Old 02-25-2010, 12:19 AM   #114 (permalink)
Yellowhand's Avatar
I made a new exhaust pipe for my Trail Horse...the bike is basically stock, so I think this new pipe looks more appropriate than the modified pocketbike muffler that was on it...
About halfway done making the intake for the taper-bore Mikuni...
Old 02-25-2010, 07:48 PM   #115 (permalink)
Yellowhand's Avatar
I have a cousin who is a professional welder/machinist, and he spends the majority of his working day running a TIG welder, so I stopped by to see him and asked if he could 'work his magic' on my wheel...
He welded the hub to the sprocket-side wheel half (Sensation Mfg welds only the other side) and then welded the sprocket to the hub..
Nice work, Z.C....thanks for doing it much better than I could have done it.
Old 02-25-2010, 10:36 PM   #116 (permalink)
Yellowhand's Avatar
I finished making the intake manifold to fit Mikuni 22mm thru 26mm taper bore carbs...
The mounting holes are differently sized and spaced when compared to a Mikuni VM22, so the manifolds won't interchange...
Fortunately, if you fab the manifolds from steel, it's only about $3 worth of materials and an hour of your time, so it's no big deal to make several different manifolds and try out different carbs to see what works and what doesn't...
Old 02-25-2010, 10:54 PM   #117 (permalink)
Yellowhand's Avatar
The yellow suede seat in the pics came off the chain bike...I dyed some new suede dark brown to make a new seat, so the yellow seat is homeless right now...and since it looks like Kenny is going to quit the seat-making business, I'll probably be buying more suede hides...
Yeah, they don't look as good as Kenny's seats, but I really enjoy making them...I make them for my little bikes and my big bikes...anything I can do to keep from sitting on the couch and watching the same crappy TV shows over and over again...
There's a piece coming up that might be interesting...those propane tanks are going to become gas tanks...round tanks go for stupid money on ebay...these are $3 each at Walmart, or $3.59 at ACE Hardware...plus some brass fittings...you might like them, and make one for yourself.
Old 02-26-2010, 12:51 AM   #118 (permalink)
bandit 40's Avatar
Them look great MarkNice Job.....Im still interested in a couple of them ,if you get around to making any more
__________________
CIRCLE TRACK RACING RULES
bandit 40 is offline   Reply With Quote
Old 03-01-2010, 01:17 AM   #119 (permalink)
Yellowhand's Avatar
There hasn't been a lot of progress lately...I took Injuntom's advice and shot the wheels with engine enamel...makes sense, since it's more durable and oil resistant...
I got sidetracked designing a tool...
I want to make some tubing that looks like linked spheres, or connected balls...think 'string of pearls' and you'll get the mental picture...
My first design was a set of dies for a press, but an uncle suggested I roll the design into the tubing instead of pressing it in...
So, I'm working on building a roller tool that uses a 1018 steel die I'm making on a lathe to form the contour into 1" OD hot steel tubing...
If the basic tool design works, I'll remake the die in heat-treated A2 tool steel so it lasts indefinitely...
As soon as I have something that works, I'll post some pics here...eventually the contoured tubing will be made into a minibike frameset, similar to the 'twisted' frame I'm in the middle of building...
Old 03-03-2010, 02:39 AM   #120 (permalink)
Yellowhand's Avatar
I needed to put new Carlisle sawtooth tires and tubes on the Sensation's one-piece steel wheels...
I put tires on one-piece wheels by hand, without any tools except shampoo...
With my luck, any tire iron or screwdriver I used would find the tube and cut it to shreds...
This set of tires was a bitch to get on, and I tore the skin on the heel of both hands from pushing the bead around the rim...
I have a set of 4-inchers I bought already mounted for another bike that were put on using a tire machine while someone wasn't paying attention to what they were doing...
They split the wire ring inside the bead, and when the tires heated up and softened, the bead stretched and one side of the tire blew off the rim...
Fortunately, the fork leg kept the tire fairly straight and the rubbing slowed the bike down without locking up the tire...
I pee'd a little, but wasn't injured...
I left the zerks in the Sensation wheels...I thought they look cool...you never see zerks on anything these days.
Reply
Lower Navigation
Tags
mb-6a, re-do..., sensation
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
sensation mb-6l Drew2 General MiniBike Talk 9 12-23-2009 10:53 AM
1968 sensation go-devil awkwardkitten General MiniBike Talk 2 12-13-2009 07:00 PM
Sensation Rim Mac Mini Bike Parts 0 08-05-2009 04:09 AM
Sensation Fenders Darvin Jahnke General MiniBike Talk 2 10-23-2008 10:01 PM
Sensation Chopper Joe Todesca General MiniBike Talk 9 06-14-2008 07:44 PM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0 RC2 Copyright 2006-2009 OldMiniBikes.com / OMB Group LLC
no new posts
