Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Project Logs
Project Logs This section is for write-ups, how-to's and project logs.
ASK QUESTIONS IN GENERAL MINI BIKE TALK - IRRELEVANT THREADS WILL BE DELETED
Reply
Old 06-19-2008, 02:12 AM   #1 (permalink)
Member
Fuel Injection Fabrication - Comments
I wanted take some photos of what Iam trying to build from the grond up. I had a sudden spin off from my EFI - Supercharged motor, and at the last minuite came up with this simple setup.
www.redneckcustoms.gotdns.com/efi/101_0270.JPG
www.redneckcustoms.gotdns.com/efi/101_0271.JPG
What you are looking at is a normal carbrator to GX200 series motor intake port, I I machined up a fuel injector boss that can easily be welded (now) to the intake manifold. My first attempts were little bit more something eles.
I then took the throttle body I made and bolted it to the manifold, it came out look nice, not as heavy as I thought it would be, the hole bore from TB, to the manifold flange is 1.080".
I wish I had something to test this on, its nearly a ready to go package :P hehe.
Next I need rebuild the superchargers exit port flange and what not.
www.redneckcustoms.gotdns.com/efi/101_0276.JPG
Another shot of the "NEW" intake manifold (thicker walls, easy weld)
BraneDeadX is offline   Reply With Quote
Old 06-19-2008, 07:19 AM   #2 (permalink)
spacecoastz's Avatar
Have you considered motorcycle throttle bodies? Injector boss already equipped, tps already equipped. Finding a small enough bore might be an issue, otherwise tip in would be a bear. Going Megasquirt? Your bringing back memories. Nice work thus far, keep the pics coming in.
spacecoastz is offline   Reply With Quote
Old 06-19-2008, 11:54 AM   #3 (permalink)
Senior Member
jesse8931's Avatar
how are you gonna control the injector
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
Heald Super Bronc VT 10
2 Honda CT 90's
jesse8931 is offline   Reply With Quote
Old 06-19-2008, 12:08 PM   #4 (permalink)
I'm quessing he'll be using a megasquirt ecu.
Old 06-19-2008, 12:40 PM   #5 (permalink)
Member
Hmm not sure what ECU to use at this point, I can snatch a megasquirt and build it up for 20 bucks no problem, I still have my old EFI board I built ages ago that I can bring back to alive.
It will be very simple to control the injector, just monitor the analog 5 volt output off the MAF and monitor the RPM, use a 2d lookup table be done with it. I plan to use engine temp and throttle position later on for enrichments, but motor this small might not need them.
Hopefully today I can machine up a new flange for my smog pump / intake manifold adapater. Does anyone know where I can find some 1.25" rubber/silicone hose? and I need find a decent K&N Style airfilter :)
Old 06-19-2008, 12:48 PM   #6 (permalink)
Senior Member
jesse8931's Avatar
thats pretty cool i hope you get it working. i have some pics of an efi setup on a briggs i have no idea who they are from tho
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
2 Honda CT 90's
Old 06-21-2008, 04:01 AM   #7 (permalink)
Senior Member
Frank Bullitt's Avatar
why not mechanical injection?
Frank Bullitt is offline   Reply With Quote
Old 06-21-2008, 04:48 PM   #8 (permalink)
Member
Hmm that sounds better yet, I have no expierence with mech. FI , I know lot of bosch back way when used it, I found intresting site that talks about how the system works.
Going this way would be better then adding more complex parts to the motor, keep it real lean and simple.
I wonder how hard it would be to fabericate a system that worked off just the motor it self instead of electronics, does anyone know anything about this type of fuel injection?
Old 06-21-2008, 06:31 PM   #9 (permalink)
Member
BraneDeadX,
All it is is like a electronic fuel pump but it is driven by the motor--
Google Image Result for http://www.rpmcat.com/images/3002END.jpg
Taylor is offline   Reply With Quote
Old 07-04-2008, 05:00 AM   #10 (permalink)
Member
I did some work on my motors, here is a quick clip i slaped together tonight, I got it running on EFI what not, I dont know why I cant get motor rev higher?
I tell you what tho, the sound the throttle body makes is insane, sounds like a 4 cycle dirt bike.
Reply
Thread Tools
Display Modes
