Go Back   OldMiniBikes.com Forum > General > Project Logs
Project Logs This section is for write-ups, how-to's and project logs.
ASK QUESTIONS IN GENERAL MINI BIKE TALK - IRRELEVANT THREADS WILL BE DELETED
Reply
Thread Tools Display Modes
Old 07-06-2008, 09:08 PM   #1 (permalink)
Senior Member
jeep2003's Avatar
Tracked 2x2 mini build
I started this about about a week ago but i didnt have a powertrain at the time but now iv got pretty much everything i need exept some rear shocks.
So i started with a set of junk yard john deere snow blower tracks with no plans whatsoever i just figured id use them someday for somthing. I got boored and decided to build a 2x2. I got a u joint from a steering rack out of a mitsubishi and a bunch of assorted sprockets from snow blowers and stuff and i went to work on the front end. This thursday i was back at teh junk yard and i spotted the tranny from a walk behind brush hog and i had a mower that i got running for the engine its a 6.25hp briggs.
So then i got the chassis made up it still needs the motor mounts.
I originally was going to put the tranny behind the engine and snake over it with the jackshaft but that would put the big sprocket too high so i figured to would work better up front because the chain can easily clear uner the carb to the rear. And since the chain is longer i wont have a problem making the rear end sprung. Im making the rear pivot from a bicycle neck. (If youve seen my other progects you know i have practice at this :) )
Im still going to run a jackshaft to the front to gear it down like the rear but theres plenty of room under the tank. Im going to sink the tank between the frame rails and run the seat on top. Ill make a seat for it. The hoops you see pictured are going to be one big hoop for the top of the frame. Im going to use heim joints for the neck. Its going to have a jockey shift on the side of the tank a twist throttle and hopefully a hand clutch but i may have to make it foot operated i havnt got to that yet.
The clutch will be lawn tractor style with a belt and a tentioner. Im going to have two sets of foot pegs that fold up for trees. Its going to go slow nothin speedy i dont thing the tracks could take too much of that kinda abuse. More of a go anywhere crawler but the tranny has 3 or 4 speeds and reverse so i can go slow and kinda quick. And i can tune it by changing the pully size on the engine and tranny without messing with the chain. Iv got about 50$ in it sofar between the tracks and tranny. Should be more than 80$ or so total.
Ill tell you what iv definatly spent more time thinking stareing at this thing than actually working on it and more thought than anything iv built before.
__________________
myspace.com/porsche930dude
Rupp C350, Bronc, Cat, Litl Red, Tracked 2x2, Trike,
Yamaha 175cc Kart, Kart #2, among others :)
jeep2003 is offline   Reply With Quote
Old 07-06-2008, 09:10 PM   #2 (permalink)
Senior Member
jeep2003's Avatar
__________________
Old 07-06-2008, 09:13 PM   #3 (permalink)
Senior Member
jeep2003's Avatar
Yes i know the front end is crooked i kinda had to build it that way. Hopefully when its all together and the chain guard is on it wont look bad. As you can see i put a spring on the front end so it can flex over bumps and stuff and ill do the same on the rear end. Ill use bicycle handlebars. Any ideas for color?
__________________
Old 07-06-2008, 09:13 PM   #4 (permalink)
jeep4me's Avatar
Sounds like a great build.
__________________
Old age and treachery will overcome youth and vigor.
jeep4me is online now   Reply With Quote
Old 07-06-2008, 11:20 PM   #5 (permalink)
Senior Member
smallbikes88's Avatar
i did a build with a track like that on the rear end and it was a awsome bike! looks great i was thinking of doing what your doing but decided the ski on the front was easier.
smallbikes88 is offline   Reply With Quote
Old 07-07-2008, 12:16 AM   #6 (permalink)
Senior Member
offroadwhatever8's Avatar
jeep, thats a nice tranny. They hold up very well. mower racers run those. Its either a 500 or a 700 peerless. Very strong. Might want to consider checking this out.
Peerless 700 Race Prep...STEP-BY-STEP (WARNING 80+ IMAGES)
good luck! looks great man!
__________________
John
My rides-
3 hp Cat 300x mini bike
1988 k5 blazer
1985 yamaha 80cc yfm 4 speed quad
2005 suzuki z-400 quad
5 hp flat head briggs go cart
and like 40 millon riding mowers
offroadwhatever8 is offline   Reply With Quote
Old 07-07-2008, 01:44 AM   #7 (permalink)
Member
wow nice work!
I really like it, keep going!
BraneDeadX is offline   Reply With Quote
Old 07-07-2008, 10:51 AM   #8 (permalink)
Senior Member
Really cool! Where can you pick up the rear track drive?What are they off of originally? THanks.
G-REX is offline   Reply With Quote
Old 07-07-2008, 08:32 PM   #9 (permalink)
Senior Member
jeep2003's Avatar
The tracks are from a snowblower iv seen a few brands that use them. I got mine from the junk yard.
Sweet bike smallbikes88 ! How deep snow does it go in? Im kind of afraid it wont go so well beacuse once i had a snowblower with the tracks and it kinda sucked. With more weight and the tracks in align and the ability to shift the weight front to back should help though i guess.
Thanks for the link Offroad ill have to read through that. I cant imagine there will be too much stress on the tranny on this bike but i did blow out reverse on the one on my jeep gocart it striped the teeth off the gear. I havnt replaced it yet but i may make it 4 wheel drive someday so ill probrobly go with a dual out tranny at that time anyway.
__________________
Old 07-07-2008, 08:52 PM   #10 (permalink)
Senior Member
jeep2003's Avatar
I might open up the tranny case just to check it and put new lube in but im not going to rebuild the whole thing. I guess it takes regular gear oil? I pulled the little vent/fill gover and it looked like real dirty greese in there. On my other tranny i used gear oil i think but that also had an abundence of greese inside.
__________________
Reply
Lower Navigation
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0 RC2 Copyright 2006-2009 OldMiniBikes.com / OMB Group LLC
no new posts
