Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Project Logs
Project Logs This section is for write-ups, how-to's and project logs.
ASK QUESTIONS IN GENERAL MINI BIKE TALK - IRRELEVANT THREADS WILL BE DELETED
Reply
Old 07-07-2008, 03:22 PM   #1 (permalink)
Junior Member
Low compression -> Need Reed Valve ?
Still suffering from no top end power even after the carb rebuild (making gaskets was a challenge). picked up a compression tester and registered some dismal numbers (less than 100). Next step the reed valve unless someone else has a better idea. If you know where I can find one please let me know. Thanks and have a great summer !
Rapini is offline   Reply With Quote
Old 07-07-2008, 07:15 PM   #2 (permalink)
If you're losing compression, you most likely need rings. Maybe even a bore job and oversized piston. You really couldn't lose copression throgh the reed valves. The piston is well above the ports when compression occurs. The pressure would have to blow by the rings to get down to the intake port in the cylinder then back out through the reed valves. Then it would still be a clearance issue with the rings/piston/cylinder.
jimh is offline   Reply With Quote
Old 07-08-2008, 02:00 AM   #3 (permalink)
Senior Member
65ShelbyClone's Avatar
Quote:
Are you talking about a 2-cycle engine or what?
__________________
In the streets the garbage lies
Protected by a million flies
The roaches so big you know that they got bones
Moved in and made a tenement home
65ShelbyClone is offline   Reply With Quote
Old 07-11-2008, 12:48 AM   #4 (permalink)
Member
yeah 4 strokes dont have reeds shelby and i would deff check out ur rings bc if ur reeds were shit u would no it lol or maybe u have a leak some where run a leak down test on her if not just pull the head and cylinder and check the rings then check the reeds to check the reeds make sure the film like stuff opens and close nicely by blowing into the back of them.
totegoterider08 is offline   Reply With Quote
Old 07-11-2008, 01:33 AM   #5 (permalink)
Senior Member
Quote:
Honda used a reed cage on their big four strokes in the early '80s. That if we knew what exactly what kind of engine we're talking about, this thread might yield more useful information.
__________________
Old 07-11-2008, 01:44 PM   #6 (permalink)
Member
yeah that would help alot what kind of engine we talking about
Old 07-12-2008, 01:21 AM   #7 (permalink)
Senior Member
dave dickson's Avatar
Project logs are for projects not asking questions
dave
__________________
Times are better with gas and a mini, and no money, than times with; money, gas, and no mini !!!
dave dickson is offline   Reply With Quote
Reply
Thread Tools
Display Modes
