Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Project Logs
Project Logs This section is for write-ups, how-to's and project logs.
ASK QUESTIONS IN GENERAL MINI BIKE TALK - IRRELEVANT THREADS WILL BE DELETED
Reply
Old 10-27-2008, 07:19 PM   #21 (permalink)
Senior Member
gbones's Avatar
well i put the engine on my mini. it barely fits. the spark plug hits the frame, but thats ok, the problem is the air filter is too big and wont fit on the frame. it fits fine when i take the air filter off but i cant ride around like that. any suggestions for a air filter that would fit?
gbones is offline   Reply With Quote
Old 10-29-2008, 11:22 AM   #22 (permalink)
Member
Try to make a new mounting plate. But move it up farther. That way it will fit. It might take a little more chain but it'll be worth it. and that way you could possibly mount a disc brake if that wasn't your plan in the first place. Good luck.
bikerboybenny8 is offline   Reply With Quote
Old 10-29-2008, 11:44 AM   #23 (permalink)
sam
Junior Member
I have a Bird that someone moved the plate forward but it is difficult to place your feet on the pegs. For the distance you would need to move it maybe easier to mount a Tecumseh in it. I have a Briggs with a Tecumseh style carb mounted to it and it seems fine. Another option would be creating an air filter out of the twist on style found on newer Briggs. I do not know how much backward and up down distance you are dealing with. I have thought of using breather caps everytime I walk into the auto parts stores. You maybe able to adjust the plate just enough to make it work.
sam is offline   Reply With Quote
Old 10-29-2008, 06:05 PM   #24 (permalink)
Senior Member
gbones's Avatar
i got my astro wheel in the mail today and picked up a breather filter last nite at auto zone, i just have to make it fit which wont be a problem. now i just need to order the other wheel, tire and tube which ill do tonite. then next week or 2 ill get the sprocket and brake and i should be ready to ride.
Old 10-29-2008, 07:43 PM   #25 (permalink)
Senior Member
gbones's Avatar
tube and tire are on the wheel. no air so ill do that at work tomorrow.
Old 11-01-2008, 05:23 PM   #26 (permalink)
Senior Member
gbones's Avatar
i cleaned the carb, and put the new air filter on today. it seems to run a lil smoother, but friggin loud. it has a muffler on it, maybe its time for a new muffler would a new muffler help? i was looking at a muffler today at ace, maybe ill just pick one up tomorrow and see what happens.
Old 11-01-2008, 07:04 PM   #27 (permalink)
GTO
GTO's Avatar
looks like the muffler lock ring is not screwed on (last pic), is it leaking at the engine?
__________________
I don't like to be Governed.
GTO is offline   Reply With Quote
Old 11-01-2008, 10:08 PM   #28 (permalink)
Senior Member
tblumer's Avatar
That muffler didn't have a baffle in it, do the stock briggs mufflers have some sort of restrictor inside them? You could look straight through the insides.
tblumer is offline   Reply With Quote
Old 11-01-2008, 10:31 PM   #29 (permalink)
GTO
GTO's Avatar
Quote:
That would explain it being LOUD! Yes stock ones have baffles and you can't see through. They are under $4
__________________
Old 11-04-2008, 06:08 PM   #30 (permalink)
Senior Member
gbones's Avatar
i ended up picking up a new muffler "with a baffle" and i got a new spark plug which is about a 1/2" shorter so now the engine sits flat on the plate. and the mail came today, i got my clutch, caliper, throttle cable, tire and inner tube. one problem though, i was hopeing to turn the clutch around so the sprocket side would face the engine. but the shaft on the motor is to short for the key to fit. i test fit the chain on the clutch and it looks like the chain may rub against the clutch housing. not sure yet, ill have to wait to get the sprocket and mount it to the astro wheel. im so frigging excited.
Reply
Tags
bird, guess)
Thread Tools
Display Modes
