Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Project Logs
Project Logs This section is for write-ups, how-to's and project logs.
ASK QUESTIONS IN GENERAL MINI BIKE TALK - IRRELEVANT THREADS WILL BE DELETED
Reply
Old 08-23-2008, 12:30 AM   #1 (permalink)
GTO
GTO's Avatar
Project Brake alignment
Jimh made me this disc for my Flea and after a lot of tweaking I finally found a way to get it reliable with a clean look.
First , I reversed the bolts and took a little off the lever and fixed part of the brake where it is close to the hub.
I free floated it by using cut recoil springs from a 1911 pistol (45acp) this allowed the brake to be move but without the feeling of being loose and rattling. With the stiff springs the brake squares up perfect on both sides of the disc when the cable is pulled. It's also fully adjustable now.
The cable return spring is from a TZ 9mm pistol and fit perfect, I lined that with a tube for the cable. The brake is easy to pull with little pressure.
I didn't have time to drop in an engine but we did the push down the hill test and the boy could lock up the rear wheel most times.
__________________
I don't like to be Governed.
GTO is offline   Reply With Quote
Old 08-23-2008, 01:29 AM   #2 (permalink)
rudedog's Avatar
awesome!!!!! very very nice!!!! both the part and the fab turned out great!!!!
rudedog is offline   Reply With Quote
Old 08-23-2008, 03:44 AM   #3 (permalink)
Top drawer all the way . looks great and nice fit.
Steve
steven Durham is online now   Reply With Quote
Old 08-23-2008, 10:50 AM   #4 (permalink)
Glad it worked. I stopped short of polishing it. I figured if I left a little "grain", it would bite a little better. I'm waiting for some stainless gears to be replaced so I can make one from stainless. your setup looks good
If I'd known you were gonna post close ups, I would have rewelded and turned the hub one more time
jimh is offline   Reply With Quote
Old 08-23-2008, 12:04 PM   #5 (permalink)
Senior Member
Quality work.
That really looks nice.
rimfire is online now   Reply With Quote
Old 08-23-2008, 03:52 PM   #6 (permalink)
Senior Member
dave dickson's Avatar
Nice job guys, looks clean and functional, where did you get the mounts attatched to the frame?, Home made or bought? cost each?
dave
__________________
Times are better with gas and a mini, and no money, than times with; money, gas, and no mini !!!
dave dickson is offline   Reply With Quote
Old 08-23-2008, 07:37 PM   #7 (permalink)
GTO
GTO's Avatar
Quote:
dave
The JS mounts are stock.
__________________
Old 08-23-2008, 07:54 PM   #8 (permalink)
GTO
GTO's Avatar
Today I did a temp mock up with a 6.0 Powersport which I think goes well with the seat and we tested the brakes real time. I also needed foot pegs so I drilled holes and installed Bonaza pegs (same as the Flea used) I also tapped the holes while I was at it (better than factory)
The gears were 13T drive and 15T to sprocket and the thing will still knock you on your butt! Even on a roll. Gobs of torque and good top end too. The little Flea looks bad ass and handle the engine well with it's tough 1" frame. (pic's don't do it justice)
Anyway, the brake worked very well, it won't put you in a skid at top speed but slows you down pretty fast. The only problem I see is heat,, the disc gets hot and so does the jack shaft in that area and I'm worried about melting the right bushing!
Looks like GTO needs to invent the bolt on jack shaft cooling impeller next to the brake.
__________________
Old 08-23-2008, 08:16 PM   #9 (permalink)
You could always run a small duct from your blower housing and/or a small scoop to catch a little air.
The jackshaft brakes turn a lot faster than one on the wheel or axle.
Old 08-23-2008, 10:26 PM   #10 (permalink)
GTO
GTO's Avatar
I'm thinking a little fan impeller blade next to the disc and maybe drill holes in the disc as well. Hahaha, it just might help!
__________________
Reply
Tags
alignment, brake, project
Thread Tools
Display Modes
