Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Project Logs
Project Logs This section is for write-ups, how-to's and project logs.
ASK QUESTIONS IN GENERAL MINI BIKE TALK - IRRELEVANT THREADS WILL BE DELETED
Reply
Old 09-01-2008, 10:01 PM   #1 (permalink)
Senior Member
Project: MTD
I started with an MTD that seems like it spent it's retirement half in and half out of a tarp. The frame was split in two places and there was a major stress crack back near the rear axle mount. After input and suggestion on this board, I had mixed feeling as to either a) start hacking away and creating a Frankenstein bike, b) completely scrap the idea and start over with another bike, or c) repair the MTD and update it a bit with a different engine and tires.
After flopping around on the ideas like an eel in a frying pan, I chose "C".
I spliced a section of frame and ground and rewelded the splits. I'm comfortable that structurely, the bike is as good if not better then the day is rolled off the factory floor. The original Tecumseh is pretty much done. I plan on rebuilding it, but that will be during the dead of winter when I lose my ability to spray paint. I bought a clone from Harbor Freight and mod parts from Affordable Cart. The govenor has been removed, a new cam installed and 1.2-1 rockers and 17lb. springs. I also bought the header and air cleaner. I'm kicking around buying the Mikuni for it, but that might wait until I see how well it runs with the stock carb. It has a 40 tooth rear sprocket, so it should have some top end to it as well.
The original torque convertor is long gone, so I bought the driver for a the TAV 30 and will use the existing 30 driven clutch. I also fabricated a drag bar style handlebar for the bike. The original handlebars look like they were the first thing to touch the roadway after falling out of the back of a pick-up. They can be salvaged, but that will be a winter project also.
At this point, I have all the parts I need except for a few wheel bearing. New throttle, cables, brake band, new tires, new foot pegs, and all new hardware. I will replace all the bearings as well.
I guess I bored everyone enough, so here some photos to look at.
Thanks,
Larry
This is the way I bought it..
Rusted driver...the inside was pitted so bad that there were holes in the clutch housing.
Frame welded, sandblasted, and primed
New tires
Frame painted in a basecoat/urethane clearcoat. Homemade seat, and original fuel tank.
Drag bars with a touch of bondo to hide the welds. I have to finish sanding the bondo.
Clone engine. The blue gas tanks it on simply to bench test it. It will not be on the engine once it's installed on the bike.
Nitrohorse is offline   Reply With Quote
Old 09-01-2008, 10:17 PM   #2 (permalink)
delray's Avatar
Nitrohorse i think you will be the first here to install a clone honda style engine on a mtd/columbia frame
.................looking good
delray is offline   Reply With Quote
Old 09-01-2008, 10:28 PM   #3 (permalink)
Senior Member
Now you have me concerned. I'm either going down a path that many have tried and failed, or I'm doing something very sacrilegious to mini bike affecinados.
In all seriousness, I'm still undecided as to which way I'll go with the TC.
SiInce there's already a jackshaft, I might mount the driven clutch on it and save myself the hassle of welding up the mounting holes on the TAV mounting plate and redrilling new holes. I'm the kind who will probably decide that at the last moment. I've been searching for a 5/8 threaded shaft with a keyway broached into it and have yet to find one. The original jackshaft is too short to install the driven clutch on it and also it's not threaded.
My last resort is to ues a 5/8 die and make some threads.
Your thoughts?
Thanks,
Larry
Old 09-02-2008, 12:24 AM   #4 (permalink)
Yellowhand's Avatar
Awesome paint...I'll bet it's even better than the camera can show.
Does that header clear the frame with that tilted engine mount plate?
Yellowhand is offline   Reply With Quote
Old 09-02-2008, 12:30 AM   #5 (permalink)
Senior Member
Wow, I was never a big fan of thoughs bikes, but I think you have converted me over... Love it... Drag pipes will really change its look too.
Kelly
dobber is offline   Reply With Quote
Old 09-02-2008, 06:41 AM   #6 (permalink)
Senior Member
Yellowhand,
There's alot more depth to the paint than the camera can pick up. I took a photo of the engine mount hoping to capture the depth, but it doesn't look like it did. You know, behind all these builds that us folks post on here is a world of "how am I going that fix that" or "shet, that won't work!". I've restored many a Wheel Horse garden tractors and it's all the same. I can admire anything that someone took the time to restore due to the amount of hours spent sandblasting, welding, painting, fabbing, etc.
Sorry for getting so winded..
The header will not fit in it's current configuration, so I will cut, weld, and bend till it does. I would like to have the header run along the bottom of the frame much like the Harley's do, but I think I'm going to have some real clearance issues. I'm hoping that the taller tires will allow for more room.
My idea was to make the bike "kind of" look like a drag or cafe style bike without altering the frame. I also was kicking round the idea of using header wrap and running the exhaust outside of the frame. My intentions are that anything I do to the bike can be returned to the original state.
Thanks,
Larry
Old 09-02-2008, 07:04 AM   #7 (permalink)
Senior Member
dave dickson's Avatar
Larry, can you hook that up direct drive, from the motor to the rear wheel? With that small sprocket, and that 6.5, it would be interesting to see if you could hold it down, and it should be real fast too!! That's if the chain don't dragg on the motor mount, you might even have to put on a pair of wheelie bars, Could you show a pic of the motor in there as it's suppose to be, I'd like to see how it looks, on that slanted motor mount, good luck with your build, the painting looks great so far.
dave
__________________
Times are better with gas and a mini, and no money, than times with; money, gas, and no mini !!!
dave dickson is offline   Reply With Quote
Old 09-02-2008, 08:03 AM   #8 (permalink)
Senior Member
Bummer! I wish you would have hosted the pics here. I could have seen them..
deezildennis is online now   Reply With Quote
Old 09-02-2008, 08:11 PM   #9 (permalink)
Senior Member
Quote:
dave
Dave,
I want to stay with the TC. I want speed and the ability to climb a hill. I was looking at the back of the bike for a place to mount wheelie bars if needed.
There's two pre-drilled holes back there that would work if I need them.
I'll post a photo of the engine on the mount once I get that far.
Larry
Old 09-02-2008, 08:26 PM   #10 (permalink)
Senior Member
Quote:
I have them under my photos now.
Reply
Tags
project:
Thread Tools
Display Modes
