Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Senior Member markus's Avatar
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    8,898
    Rides
    Western Flyer ss300
    Got most of the parts I need and been tinkering a little with it so I'll start a build thread. The bike is a Western Flyer ss300 I bought it off a buddy that abandoned it as a project. Entire bike had multiple layers of paint as seen on the rear fender on this pic, He stripped the bike down and got it got it pretty close to ready for paint and gave up.
    Th frame is in great shape no pits or damage smooth tubing all the way around. The wheels were still rusted and pitted when I got it so I blasted them, welded up some holes and just recently finished painting them. I sprayed the halves with silver the insets with black and then cleared them with automotive urethane clearcloat (not a great pic but they came out nice)
    I have decided to use a sloppy repro Rupp seat I had from a bike a recently parted out. The seat, or cover at least, is new but its nothing like the real Rupp seats were. So I figure I'll make use of it on this bike. I also just got my order from OMB warehouse in today which was new fenders, brake parts, chain, etc...
    The motor in the frame is from my Cat 350ss I had. There is an internal problem in it. I will be tearing it down to see what needs to be done. Worst case I have a fresh 3.5 short block thats been sitting around to either swap out or pull parts from.
    I'm getting ready to paint the frame, Not getting dark here till late and the clearcoat that I bought is very forgiving so I can get some stuff done in the early evening after work. Still stuck on choosing a color though For actual automotive base coats I have black, red, some silvers. I can spray it with just about anything out of a rattlecan and lay the clear over it as well, but I would like to use actual basecoat for better durability.
    I did a search on ebay for Western Flyer decals to see if there was anything I could make use of. There actually is alot of neat decal repros for the WF bicycles. I emailed one seller and he said he could enlarge just about any of the decals he was making for a few bucks more, so I am comparing a few and trying to find a good fit for that forkplate.
    I was thinking about something as simple as this:
    maybe even something like this:
  2. #2
    Senior Member TomH's Avatar
    Join Date
    Jun 2010
    Location
    close to Tulsa
    Posts
    3,493
    Rides
    I like the second one. Your project is coming along real nice.
  3. #3
    buckeye's Avatar
    Join Date
    Oct 2010
    Location
    L.A. Lower Alabama
    Posts
    28,362
    Rides
    Cool, a Marcus build.
    Guess the style of decal, depends on the color you choose.
    Look forward to this project as your build history is stellar.
  4. #4
    Senior Member Mr.GhettoRig's Avatar
    Join Date
    Aug 2010
    Location
    Port Charlotte, Florida
    Posts
    1,024
    Rides
    I like it I think the second decal matches with the Tecumseh decal on the engine a little better than the first.
  5. #5
    Senior Member
    Join Date
    Mar 2012
    Location
    Wyoming Mi
    Posts
    1,117
    Rides
    Nice project, did my wheels the same way, painted mine a medium metalflake blue, with the Honda 5.5 and the longer wheelbase this is one of my favorite riders at this point..........Keep the pics comming!.............Tom.
  6. #6
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    8,898
    Rides
    Between working on my truck, trip to home depot, and yardwork I found a few minutes to mess with the WF. I drilled some holes in the new fenders I got from OMB to do some test fitting, finished the wheels and mocked it up to see how it would look.
    I really like some of the little touches that MTD did with this frame, but my favorite thing of all are the bolts for the wheels. They are pointed, after a little polishing up I think they look cool as hell even though they are not real noticeable
    I'm torn between red or black now for the frame, still torn on decals as well, the 2 I posted are just the tip of the iceberg for choices actually. I did blow up that bigger one I posted, printed it and cut it out to try on the fork plate. Its not bad. I would like a hint of gold here and there since that seat has the gold piping.
  7. #7
    YOOP's Avatar
    Join Date
    Jan 2012
    Location
    THE NORTH POLE
    Posts
    9,088
    Rides
    THAT'S A NICE ONEGREAT JOB MARKUS
  8. #8
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    8,898
    Rides
    Wanted to take the boat out today but theres no getting into the boat ramp down the street thanks to everybody and their brother wanting to do the same thing Good thing I guess as I wanted to try out some slight changes I made and I am sure that the PO-PO is out in force and they tend to frown upon you doing 60mph through the inter coastal waterway
    So I stayed in the garage and started working on the WF. I welded up the 2 holes for the original chainguard that were at the rear of the frame, Stripped it back down and wetsanded the frame. Last shot before some color:
    The whole time I was wetsanding I was trying to make a decision on the color. I went through a bunch of paints a buddy had given me before he moved. I was pretty set on Victory red (chevy color) but this morning when I was welding I decided to dig out one of the Bonanza's and weld up some holes a previous owner had drilled into it and I was reminded that It was originally red so I figure I'll save that paint for that one. So next choice was Black, I had some solid Ford Black, and some Black with "effect" in it, just a hint of metallic, I chose that one because I have alot of it Its Nason/Dupont-which I cant stand but it was free
    As I write this I am waiting for it to set up some more, couple of weird spots in it. I think I may have not mixed enough in enough activator, plus all this product is pretty old. It looked like it was setting up good so I I'll give it a little time and go back out and mix up some clearcoat.
    Peekster is sending me one of his chainguards that I will use for this bike, still undecided on a decal as of now. If the clearcoat cooperates I'm gonna clear a spot and start on the motor.....if it doesn't, I'm gonna run it over with my truck
  9. #9
    buckeye's Avatar
    Join Date
    Oct 2010
    Location
    L.A. Lower Alabama
    Posts
    28,362
    Rides
    Oh no, not run it over with the truck.
  10. #10
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    8,898
    Rides
    Quote Originally Posted by buckeye View Post
    Success! Suns going down so I could not get a good shot of the color It changes quite a bit depending on intensity of light though.
    Now if I can just keep my grubby hands off it for the rest of the night I may not F**k it up!
Similar Threads
  1. fenders needed Western Flyer SS300
    By wheels1950 in forum Mini Bikes & Parts WANTED
    Last Post: 03-03-2012, 04:31 PM
  2. Is this a Western Flyer SS300?
    By zeeman in forum What is it?
    Last Post: 08-13-2011, 09:54 AM
  3. Western Flyer SS300 MTD
    By jricherson in forum Complete Mini Bikes
    Last Post: 04-07-2011, 05:19 PM
  4. Western Flyer SS300 Need help!
    By jricherson in forum General MiniBike Talk
    Last Post: 07-06-2010, 04:15 PM
  5. Western Flyer SS300 frame
    By minibikin' in forum Mini Bike Parts
    Last Post: 06-30-2008, 05:01 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
