Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Project Logs
Project Logs This section is for write-ups, how-to's and project logs.
ASK QUESTIONS IN GENERAL MINI BIKE TALK - IRRELEVANT THREADS WILL BE DELETED
Reply
Old 09-24-2008, 03:51 AM   #1 (permalink)
Oldsalt's Avatar
Streached Alex-Reyn With Big Block
Was given an Alexander-Reynolds by a friend of my youngest son. It had been hit by a gang disk when the lot it was hideing in was being plowed. Had a pic of the bike before taking it apart but for some reason it won't upload[?]. The attached pictures are of the front wheel...before and after it was repaired. Had to straighten the rim and the center and had to make a new hub and weld it in. The other pics shows the frame has been chopped apart and "slugs" have been made to extend the frame 4" and raise it 1-1/2". That's necessry to do if a large engine is to be installed. In this case a Tec cast iron 6 HP that has a 1" dia. output shaft. Really, this frame and forks were so bent by the encounter with the tractor that it would never be a candidate for restoration. The last pic shows rhe frame tacked up with the engine and Comet 30 vari-speed drive. The engine was given to me for working on a guys mini. I found the Comet in the back seat of a 51 Merc. a friend had just purchased. So far all parts have been for free.
Oldsalt is offline   Reply With Quote
Old 09-24-2008, 04:03 AM   #2 (permalink)
Member
nice cant wait to see it finish. i have the same minibike.
Bigtank05 is offline   Reply With Quote
Old 09-24-2008, 04:49 AM   #3 (permalink)
Oldsalt's Avatar
Quote:
BT
As you have one of these things maybe you can tell me what the two bent metal tabs are neer the top of the forks. [See last picture]. If the tabs were straight out, without the 90 degree bends, they might be used to mount a headlight. Did they hold a number plate? Can you post a pic of your machine? I know very little about this brand.
Old 09-24-2008, 06:26 AM   #4 (permalink)
Senior Member
OS,
I like the "drag bike" look of the stretched frame. With the 6hp Tec, it should have the power to get you safely up to highway speeds...
Not to change the topic, but is that a Fairbanks Morse 4 cylinder in the background?
Also like the Enfield in the photo. You're certainly a diversified man with when it comes to "toys".
Nitrohorse is offline   Reply With Quote
Old 09-24-2008, 07:49 PM   #5 (permalink)
Senior Member
jesse8931's Avatar
Quote:
Originally Posted by Oldsalt View Post
BT
they hold a number plate check my pic's out i had the same one
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
Heald Super Bronc VT 10
2 Honda CT 90's
jesse8931 is offline   Reply With Quote
Old 09-24-2008, 11:59 PM   #6 (permalink)
Oldsalt's Avatar
Quote:
Thanks Jesse. In that cae I'll probably cut the tabs off. Hell, the frame has been butchered so it can't get any worse. Any idea on the approx. year the A-R was made?
Old 09-25-2008, 12:19 AM   #7 (permalink)
Oldsalt's Avatar
Quote:
Originally Posted by Nitrohorse View Post
OS,
Nitro
Been wanting to streach a frame and this was a good opportunity because the frame had to be cut apart just to straighten it. At that point it was decided to also jack up the heigth of the frame to accomodate the tall big block motor. I expect it to be fairly quick in comparison to most mini bikes around Walla Walla.
The old 4 cylinder engine in the background is a 1915 Holt. That was the tractor company that became Caterpillar. It's a 45 HP. They also made them in 60 HP and, I belive a really rare 75 HP. I'm not an expert on Holt engines, this is the only large tractor engine that I own. Had to make a lot of parts to make it run.
Ya. The Royal Enfield is another toy. The last 500cc single made by Royal Enfield in England was 1955. But They sold all the tooling and patterns that year to India so they could make military and cop bikes. These things have been made in India since '55 with little change. That one is a 2006 model! Bought it new for 3800 bucks.
Old 09-25-2008, 12:40 AM   #8 (permalink)
Oldsalt's Avatar
Today was exhaust pipe and drive guard day.
The pipe was made from the bent end of a weed eater tube. Chopped in sections and rewelded with the bends positioned to clear the stock air filter and also clear the rear fender and still be parallel with the frame tubes. The limp wrested federally mandated "Safty Notice" stickers are still on the weed eater tube. A brace, off the Comet back plate up to the pipe, will be added so that it won't vibrate off the engine.
Aluminum guards were fabricated for the Comet belt drive and the chain drive. Tomorrow they will be polished and mounted.
Old 09-25-2008, 11:18 AM   #9 (permalink)
Senior Member
smallbikes88's Avatar
The enfield is awsome! i lie those bikes alot. Also the mini looks like its coming along well
smallbikes88 is online now   Reply With Quote
Old 09-25-2008, 10:13 PM   #10 (permalink)
Senior Member
OS,
The "Walla Walla Rocket" looks good. I like the fabbed jackshaft. You gave me an idea that I might have to "borrow." I will drill and tap a set of internal threads on the rear jackshaft. I have a foot long jackshaft with a keyway broached into it. I was going to use external threads to mount the driven sheave, but the internal will be easier since I already have the drill and tap.
On another note, there was a hugh Holt show in Cali this past summer. From what I read, it was a once in a lifetime show. With gas/diesel prices what they are and the weight of hauling a complete Holt tractor around, I can understand why.
I have a small collection of hit and miss and antique Briggs, Maytags, Nelson, etc. I certainly have enough, but I would like to restore an old motorcycle.
I had a chance to buy an old Triumph Bonneville but farted around too long on it and the guy sold it.
Oh well, there will be other bikes in the future.
Larry
Reply
Tags
alex-reyn, block, streached
Thread Tools
Display Modes
