Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Project Logs
Project Logs This section is for write-ups, how-to's and project logs.
ASK QUESTIONS IN GENERAL MINI BIKE TALK - IRRELEVANT THREADS WILL BE DELETED
Reply
Old 10-16-2008, 10:14 PM   #1 (permalink)
randyk72@verizon's Avatar
Rupp TT500 Build
This is the before picture of my TT500. Pretty much complete as I got it. I bought this bike in July 08. When I brought it home I stripped it down to bare parts. I stripped the frame, fork uppers and swing arm using paint stripper and elbow greese. Once I hade it to bare metal I repaired the couple rust spots and also repaired the right side jackshaft mount.
File Type: gif tt 500.gif (1,006 Bytes, 29 views)
randyk72@verizon is offline   Reply With Quote
Old 10-16-2008, 10:19 PM   #2 (permalink)
Before Pic
File Type: jpg 01010601030401040420080731a28587e34d0af19462003ddf_1_.jpg (12.6 KB, 54 views)
Old 10-16-2008, 10:27 PM   #3 (permalink)
The pivot rod was frozen in the swing arm but with a Lotta heat and a little luck I was able to free it up. I'm going to cut grooves in this and put a grease fitting in the bottom of the arm. That way it can be greased. The holes you see in the bottom of the swing arm where drilled by me. They enabled me to get penetrating lube in to help free up the pivot. The outer 2 will get welded shut and the center hole is getting a grease fitting.
Old 10-16-2008, 10:54 PM   #4 (permalink)
These pics show the frame, swing arm and fork upper. These parts where stripped to bare metal. I needed to do a small amount of body work and then they where primed with a etching primmer and then 2 coats of a filler primmer to smooth everything out. As you see them, there ready for paint. The extra time spent on the primer should make a world of difference in the quality of the paint job. The one photo is of my bikes VIN. I kept sanding the primer off of it so it will "I hope" show up through the paint. When I paint it, it will be electric blue with a few coats of clear. But it's going on the back burner for now, I'll post more when I have them.
Old 10-18-2008, 06:49 PM   #5 (permalink)
Frames Painted
I shot the frame today. I wanted to use a Corvette Electric Blue but I had this paint on hand so I went ahead and used it. It's close enough for me and I already had the paint so it really did not cost me anything. It is a early 90's G.M Blue called Medium Quasar Metallic. I shot it with three coats and two coats of clear. I'm real happy with it. It has a lot of depth. Much nicer then the photo's show.
Old 10-18-2008, 07:05 PM   #6 (permalink)
Senior Member
gbones's Avatar
very nice.
gbones is offline   Reply With Quote
Old 10-19-2008, 01:59 PM   #7 (permalink)
Starting to assemble
Here are a few pics of the bike.
Old 10-19-2008, 02:17 PM   #8 (permalink)
Member
looks good if u or r buds need a mini i got 69 roadster iam looking to off load
bsdb420 is offline   Reply With Quote
Old 10-22-2008, 11:44 AM   #9 (permalink)
2 speed on TT500
[img] http://www.oldminibikes.com/forum/ph...ayride_027.JPG [img]
Reply
Tags
build, rupp, tt500
Thread Tools
Display Modes
