Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. #21
    Member
    Join Date
    Nov 2016
    Location
    Vine Grove, KY.
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I'll upload pics later if I get time, but I finally finished the mini bike yesterday. It's scary fast, but the problem is that it's idling super high and it engages the clutch as soon as I start it up. And it keeps throwing the chain. From what I can see, it looks like it's aligned perfectly. But I'm glad that I just kept the motor stock. adding more would just be overkill. it's not as torquey as I thought it was going to be, which is fine because it's right where I want it to be performance wise. I'm going to have a lot of fun when I get this chain issue straightened out.
  2. #22
    Join Date
    Aug 2016
    Location
    White Lake , Michigan
    Posts
    274
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The chain popping off even when it looks straight can be caused by a couple different things or a combination of things.
    Are you using the old chain? If so, that could be the issue. I've experienced this on a couple mini's and also on my T-Bird. I tried aligning things, tightening the chain etc to no avail. It simply was stretched and wouldn't line up with the tooth spacing on the sprockets and it would come off. A new chain solved all issues.
    Buy a new chain and try that.
    Another issue is a known problem with T-Bird's. The engine mounting plate will twist or flex when TQ is applied. You need to reinforce it good and solid to stop that from happening.
    Idling fast? Are you still using the governor? How did you hook up your throttle cable? Have you tried turning the idle screw counter clockwise to lower it?
    Slap on a new chain and stiffen the motor plate and you'll be doing wheelies very soon.
    Danford1
  3. #23
    flpmurphy's Avatar
    Join Date
    Dec 2011
    Location
    nicholasville ky
    Posts
    358
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I had problems with chain popping off on thunderbird my brother had. I orderd a 60 tooth rear sprocket #35 chain. After that i had no problems with it running a briggs 6.5hp
  4. #24
    Member
    Join Date
    Nov 2016
    Location
    Vine Grove, KY.
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by danford1 View Post
    Danford1
    I wish it were that easy with the chain. the clutch chain and sprocket are brand new. Now I didn't think about torque flex, but I don't think that is the issue. My best guess, and I've been at work all day to ponder this; and either the motor is vibrating backwards and giving the chain too much slack causing it to throw the chain or it's out of alignment just barely enough to throw it. And I am still using the governor. All the reading I've done today tells me that I need to check that throttle bolt that was tightened down for shipping and make sure that the idle screw is out, and to make sure that the butterfly isn't stuck open. if none of those fix it, I will post a video or some pics of my issues.
  5. #25
    Dr. Shop Teacher's Avatar
    Join Date
    Feb 2015
    Location
    Falmouth, Virginia
    Posts
    2,483
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Torque flex is going to be a contributor. Rather than weld up the plate like Danford did, I used the engine and made a girdle to lock the front of the plate to the engine. Since the rear of the engine sits right on the cross member, it'll lock it in place. Worked great with the GC160 I had on my 'Bird.
    Wilderness~Copperhead~Trail Bike
  6. #26
    Join Date
    Aug 2016
    Location
    Posts
    274
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Dr. Shop Teacher View Post
    Can you post a picture of this girdle you made. Sounds slick
    Danford1
  7. #27
    Join Date
    Feb 2015
    Location
    Falmouth, Virginia
    Posts
    2,483
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Girdle
    Danford1
    Here you go--
  8. #28
    Join Date
    Aug 2016
    Location
    Posts
    274
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Here you go--
    Thank you.
    Danford1
  9. #29
    Member
    Join Date
    Dec 2016
    Location
    Southington, CT
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Here you go--
    You should sell those. Bet many would buy one. Some of us dont have the tools let alone the fabrication skills.
  10. #30
    Member
    Join Date
    Nov 2016
    Location
    Vine Grove, KY.
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    You really should sell them Dr. Shop Teacher, I have the fabrication skills but I just don't feel like doing it right now. I know I will have to very soon though.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
Similar Threads
  1. Manco Thunderbird Budget Build
    By Dr. Shop Teacher in forum Complete Mini Bikes
    Last Post: 09-22-2015, 10:58 PM
  2. Manco Thunderbird Budget Build
    By Dr. Shop Teacher in forum Projects & Rides
    Last Post: 06-11-2015, 08:49 PM
  3. Manco Thunderbird Budget Build
    Last Post: 04-09-2015, 05:26 PM
  4. Manco Thunderbird not a stock build
    By hogbuoy in forum Projects & Rides
    Last Post: 05-22-2014, 10:00 AM
  5. Manco Thunderbird snow bike build
    By JackLambert in forum Projects & Rides
    Last Post: 08-30-2013, 08:58 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
