Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Shop Tools
Shop Tools Ask questions and discuss anything about tools. Post up good deals, bad deals, etc!
Reply
Old 06-12-2008, 04:37 PM   #1 (permalink)
Member
jwmikecz's Avatar
harbor freight spray guns
i picked up some of the purple spray paint guns. has anyone had any luck with these? if so do you recommend any type of paint for them?
jwmikecz is offline   Reply With Quote
Old 06-13-2008, 09:14 PM   #2 (permalink)
Senior Member
jesse8931's Avatar
is it the gravity feed one ?
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
Heald Super Bronc VT 10
2 Honda CT 90's
jesse8931 is offline   Reply With Quote
Old 06-13-2008, 09:20 PM   #3 (permalink)
spacecoastz's Avatar
Make sure of what you bought. They sell gravity feed feed guns and hvlp. They look the same but operate totally different. HVLP= high volume low pressure. I personally went with the Titan brand hvlp's and never looked back. My siphon guns are just primer guns now. Check out some auto painting forums, a lot of experts are moderators and will steer you correctly.
spacecoastz is online now   Reply With Quote
Old 06-14-2008, 12:04 PM   #4 (permalink)
Senior Member
thebronc4019's Avatar
See my post under this category from April 1. The Harbor Freight 43430 is a very good gun for the price. With the 1.4 MM tip you can spray any automotive paint except for very heavy filler primers.
thebronc4019 is offline   Reply With Quote
Old 06-16-2008, 08:51 PM   #5 (permalink)
Junior Member
Nice Nova Bronc...I have one too!
I've been using the Harbor Freight guns for years and I've never had a problem with them. My favorite is the purple gravity feed detail gun for small parts.
I like using epoxy primer on bare metal. The Kirker brand is my favorite. For building and filling I like Slicksand polyester primer surfacer by Evercoat. Thick stuff but can be reduced with acetone to get it out off the gun if you have a small tip.
For topcoats, I use Nason acrylic enamel with hardener added for most of the jobs I do. they also make a pretty good acrylic urethane.
loneagle is offline   Reply With Quote
Old 08-08-2008, 12:50 PM   #6 (permalink)
Junior Member
I have the detail gun and the bigger one, both purple. I am a painter in process. The detail gun I have used in paint tractor implements stuff. I have just used rustolem oil based paint thinned with lacquer. Works well IMHO.
Dan
excelagator is offline   Reply With Quote
Old 10-28-2008, 11:56 AM   #7 (permalink)
Member
donkeypop's Avatar
I'm a varnisher by trade and I like the purple paint guns from there, they work surprisingly well for the money. Re: HVLP systems....i don't own one of these but i've used them and they rock
donkeypop is offline   Reply With Quote
Old 10-28-2008, 04:35 PM   #8 (permalink)
I have always been under the impression the HVLP painting was with the use of a machine that provided pre heated air and paint blend @ low pressure.
The guns on Harbor Freight just look like normal gravity flow guns.
I of course have only very limited experience and use the rattle can method. I have been thinking of making one of my small storage rooms into a painting room that I can control the temperature and dust. As winter is here and we all know how the cold effects the flow and paint adhesion.
Steve
steven Durham is online now   Reply With Quote
Old 10-30-2008, 08:21 AM   #9 (permalink)
Steve
There are different types Steve. I think your referring to the turbine setup. It basically "pumps" the paint thru. Where as the other uses a large compressor at low pressure to push it. I've never used the turbine setup.
Old 10-30-2008, 10:46 AM   #10 (permalink)
Member
donkeypop's Avatar
I've actually used a turbine setup HVLP for varnishing...it's a small machine looks like a small amplifier with a large hose leading to the spray gun...once you get used to the setup it is a lot easier to tell how much varnish it is putting on than with a compressed air gun.......it's not so important with paint, but with varnish there is a fine line of putting on too much and putting on too little. But yeah the purple paint guns at HF are just gravity feed to be used with air compressor. The HVLP i was using belonged to the boatyard i was working in....don't really spray enough to own one myself...most of the stuff i do i can still do the old fashion way...with penetrol and a brush!!
Reply
Thread Tools
Display Modes
