Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Shop Tools
Shop Tools Ask questions and discuss anything about tools. Post up good deals, bad deals, etc!
Reply
Old 07-11-2006, 04:22 AM   #1 (permalink)
Junior Member
I'll start.
This project cost me a total of $230.
I started with many different sized tubing, you can use whatever size you can acquire. Everything is 1/4" to 3/8" wall. I had very rough plans, only knowing some specifics that I wanted. Like a 36" throat, and a certain wheel height for ease of use. Other than that, I just went with it.
In this first picture, I have placed the upper bar, and have the upper brace cut.
This is roughly where I wanted things...
I took measurements there, and got it standing.
Then braced it so that it could hold it's own weight, and added the upper wheel.
Now, the upper wheel took a bit of creativity. Rather than goign out and spending over $200 on a nice upper wheel, I opted to go the cheaper, yet still nice, route. I bought a 2.125x6.25 bearing (metric), and machined an axle. The hole in the center was just over 1 5/8", so I started with a chunk of 1 3/4" round stock, and made myself an axle.
[If you do not have a lathe, this could be tricky, and a proper upper wheel may be the cheaper route.]
Here is the wheel and axle, along with the mounting bracketry.
The wheel fits snugly over the axle, but I further insure that it will stay in place with a hard tar-like epoxy. It has not yet moved.
This is how it is attatched to the frame [note: there are now nuts on top of those bolts for added security]
I got a bit creative on the lower adjuster as well. I used a tow-hitch adapter and 2" tube in the center. I also used 1" Acme thread, and nuts for this.
I welded one nut to the 2" tube [I machined it so that 3/4 of the nut sunk into the tubing, for added strength]. I then threaded the Acme thread through the nut, until it was near the other end of the tube. I then welded the lower nut to the Acme thread, seperate from the nut in the tube. This assembly slid down into the tow-hitch assembly, with one boxed end. I made two 3/4" round bar handles, and welded them to another nut. I also drilled and tapped a hole in this nut, for a set screw. I put this handle on the bottom fo the entire assembly, and set it in place. I was now able to adjust pressure/height of the lower anvil with the handle on the bottom. My design allows the anvil to move up/down, without the handle moving up/down.
And here it is, pretty much completed, minus the casters for moving the whole thing around. The casters are a good idea, as the whole thing weighs over 400 lbs...
Here is the cost list:
Upper bearing - $60 (SKF 5313-2PS)
Three lower anvils from Hoosier Pattern - $140
6" of 1 3/4" rod - $8
3 feet of Acme thread, and 4 nuts - $15
Tow-Hitch/2" tube - $6
That adds up to $229. Now, the tubing for the wheel will probably cost you a good deal of money, if you decide to buy it new. I happened upon the pieces I used at a scrap yard, and got them for free because they were all off-cuts.
I hope this can help someone to make an english wheel. They really are worth the effort and money to build one.
Seth
__________________
A different breed...
Twisted Minis is offline   Reply With Quote
Old 07-11-2006, 12:13 PM   #2 (permalink)
Good job Seth, I'm sure this information will be useful to all of us! :!:
__________________
OldMiniBikes.com
Hent is online now   Reply With Quote
Old 08-15-2006, 10:45 AM   #3 (permalink)
Senior Member
Jim "Barndawg"'s Avatar
Nice English wheel Seth. Did you ever paint that ugly rust? I might just build me one when I get some time to play with sheel metal.
Thanks for the udeful post. I hope to have some things posted before too long.
Maybe you can make it out here for the trail ride in Sept. Check it out on the front page.
Ciao, BarnDawg
Jim "Barndawg" is offline   Reply With Quote
Old 07-15-2007, 07:24 PM   #4 (permalink)
Bump. This is a good thread, maybe some of you newer guys will enjoy it!
__________________
OldMiniBikes.com
Old 07-16-2007, 01:22 AM   #5 (permalink)
Supporting Speed Nut!
Moderator
Moderator
minidragbike's Avatar
That's sweet, I wasn't around when this thread came out. Real nice work!
__________________
Push hard, or don't push at all!
minidragbike is offline   Reply With Quote
Old 07-16-2007, 01:56 AM   #6 (permalink)
Senior Member
CaliJeff's Avatar
Cool. It's been a year...are there any parts made on that to take pictures of?
CaliJeff is offline   Reply With Quote
Old 07-16-2007, 03:02 PM   #7 (permalink)
Senior Member
jesse8931's Avatar
me and my grandpa used this as a guild on how to build so we did but its in ohio now till we move
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
Heald Super Bronc VT 10
2 Honda CT 90's
jesse8931 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Suzuki Trail Hopper Kick start oldsledz Mini Bikes & Parts WANTED 4 01-04-2008 06:01 PM
Kick start? nutwagonfromhell General MiniBike Talk 8 04-26-2007 12:35 AM
kick start jeep2003 General MiniBike Talk 0 02-04-2007 12:04 PM
whisker mini cat w/sachs will not start earl General MiniBike Talk 6 07-15-2006 07:27 PM
