Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Shop Tools
Shop Tools Ask questions and discuss anything about tools. Post up good deals, bad deals, etc!
Reply
Old 10-19-2008, 08:29 PM   #1 (permalink)
Senior Member
briggs_boy's Avatar
bench grinder and drill press ? ? ?
i was thinking about investing in a new bench grinder and drill press.
any suggestions or favorite brands ?
__________________
flatheads forever !!!
LOTS OF STUFF FOR SALE !!!
http://www.oldminibikes.com/forum/mi...-my-stuff.html
briggs_boy is offline   Reply With Quote
Old 10-19-2008, 11:07 PM   #2 (permalink)
Member
how often will you use it, ya know harbor freight has some decent stuff and inexpensive. just a thought also if you dont need asap watch craigslist for better qaulity at cheap prices good luck..
tanker2008 is offline   Reply With Quote
Old 10-19-2008, 11:44 PM   #3 (permalink)
Senior Member
briggs_boy's Avatar
i will be using them very often.
__________________
Old 10-20-2008, 04:20 AM   #4 (permalink)
Oldsalt's Avatar
I agree that you probably should be looking at Harbor Freight for your first drill press and bench grinder. Sure, there's a lot better stuff out there but when you're just beginning to collect tools you shouldn't spend all your loot on one high zoot machine. Buy fairly cheap stuff and get several tools. My experience with Harbor Freight drill presses is that they are adaquate for your needs [all except for the very small one]. However, some care should be exercized to ensure you don't overwork the tool. Same with the bench grinder, but don't buy the smallest. By the way, the worst luck I have had with power tools over a span of 40+ years has been Craftsmen!
Oldsalt is offline   Reply With Quote
Old 10-20-2008, 12:51 PM   #5 (permalink)
Senior Member
briggs_boy's Avatar
well i am going to use the out of them so i want something good.
__________________
Old 10-20-2008, 02:11 PM   #6 (permalink)
Senior Member
Quote:
X2
Until about a year ago or so... I had a personal boycott on Harbor Freight products. I firmly believe that that every American has a certain level of responsibility to make every attempt to always purchase products that are manufactured in the USA.
Eventually I found myself spending far too much time researching a products origin & the field of selection was becoming very slim. I still believe that the proliferation of Chinese manufactured products is an issue that needs to be reversed.
Eventually I became very weary of , plus I moved to a new neighborhood that has a Harbor Freight less than 5 miles away.
So... Enough of the political doom & gloom. Harbor Freight does offer several products worthy of purchasing. Especially if you have a store nearby. The Chinese usually can not produce the quality of steel or iron that can be had here or in other countries. This generally results in tools that are more bulky & clumsy to operate. Often it results in more effort on the operators part to produce the quality of work desired.
Definitely watch Craigslist DAILY!!! This will most likely be your best bet at buying an older manufacture, higher quality tool, at a reasonable price. Make sure you check the FREE section also. I missed out on an older full size metal cutting band-saw by about an hour once. The people just wanted it removed from the property. You also want to make sure that you have some cash stashed away & you're able to move in an something fast if you can, or it will be gone.
I'm pretty much in the same boat as you right now. I have a small bench mounted drill press that works fairly well. I also have a small bench-mount style belt & 6" disc sander. I did invest wisely into a fine, 'Made in the USA', Wilton bench vise. It is one of my tools that I'm very proud of & I enjoy feeling the quality of the tool every time I use it.
I remember reading an interview of Li'l John Buttera in one of the Hot Rod type magazines when he first began to be well known. In that article he stated that you could accomplish almost everything he could, with only 3 power tools. One being a drill press, one being a bench grinder/sander & the other being a band-saw. Recently, I have been told a few times, that if you can pick up a mill instead of a drill press you would be much better off.
Hopefully you will find some useful nuggets of information in this old man's ramblings. I'd be interested in hearing about what tools you end up with.
Here's a little part I made recently with the tools mentioned above.
This part will replace the missing dip stick tube retention bracket on my lawn mower.
Good luck on your hunt.
__________________
WWW.CADDY500.COM
High Performance Big Block Cadillac Forum
~JM~ is offline   Reply With Quote
Old 10-20-2008, 06:54 PM   #7 (permalink)
rudedog's Avatar
Man I almost thought it was a distributor hold-down for an old v-8 car project you might have stashed away.
Nice piece just for a lawn mower.
rudedog is online now   Reply With Quote
Old 10-20-2008, 11:14 PM   #8 (permalink)
Oldsalt's Avatar
Quote:
Sorry for my assumption that you're not a high roller. In which case I can reccommend a Jet 20" drill press. I love mine. It will be able to handle your continous work. See the Travers catalog. Model #JDP-20VS-1. They start at $2,911. They're made in Taiwan ROC, that's why they are so resonably priced. If you want USA built you may be out of luck unless you're willing to purchase a used machine. Currently there are no 'manual' machine tools being built in the U.S. [We do make some nice CNC stuff however]. That includes mills, lathes, suface grinders, and I'm sure drill presses.
Old 10-21-2008, 04:27 AM   #9 (permalink)
Senior Member
Thanks. It is a bit racy for an old lawn mower, but what the 'ell. I had found the original stamped steel part laying out in the yard one day. I couldn't figure out what it was at the time. About a month or two later, the lawn mower develops an oil leak. All of a sudden I realize what that part was that I had found.
Do you think I might have any idea what I had done with it? Not a clue!
The idea of a distributor clamp had occurred to me when I was making that little part. I think that will be one of my next projects.
__________________
WWW.CADDY500.COM
Old 10-24-2008, 05:12 PM   #10 (permalink)
Member
North Ga. is a way from Melb. Fl. but I have a large floor standing drill press that is way more than I will ever need. It suffers a little from non-use not abuse. It's old, I'm guessing circa 1960. It's a Craftsman most likely made by Delta or Rockwell. It is 6ft tall and has to weigh 200 lbs. I have put a new grounded cord and plug on it. There is surface rust, but if you know cast iron. It can be cleaned and polished to look like new. Oh, yes it does run. As you can see a new one like costs $3000. I will let it go for $250. If you are interested my e-mail is bushclan@bellsouth.net and I will send pictures.
Bushman is offline   Reply With Quote
Reply
Tags
bench, drill, grinder, press
Thread Tools
Display Modes
