Follow us on...
User Tag List
Thanks Thanks:  11
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    FOMOGO's Avatar
    Join Date
    Jan 2016
    Location
    Upstate, SC
    Posts
    578
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Anybody have any Jackshaft installation tips and tricks
    I am getting to the point that I need to purchase and install a jackshaft on my Build Off bike. It is a Baja Warrior that Is stretched and has a 420cc Predator going in it. I have a 40 series TC for it and I will need a 3/4 jackshaft.
    Do you have any tricks for squaring up all the pieces? Engine, jackshaft and axle? Any advice on what to make sure that I do and don't do?
    It should be pretty straight forward but I would like to only do this once. I have messed with a few Go Karts over the years but I have never had anything that had a jackshaft so this is all totally new to me.
    Thanks for any and all advice!
    Doug
  2. #2
    CarPlayLB's Avatar
    Join Date
    Aug 2012
    Location
    Long Beach, CA
    Posts
    5,404
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Doug, why use a jackshaft and a TAV? Is there some alignment issue? Can you mount the motor where the gears are aligned?
  3. Thanks FOMOGO thanked for this post
  4. #3
    Senior Member Raskin's Avatar
    Join Date
    Jul 2016
    Location
    Florida
    Posts
    581
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Dunno if help you..probably that fat engine is not allowing chain alignment from tav to rear sprocket ..what about a pillow bearing block with sprockets on either side to align..
  5. Thanks FOMOGO thanked for this post
  6. #4
    FOMOGO's Avatar
    Join Date
    Jan 2016
    Location
    Upstate, SC
    Posts
    578
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by CarPlayLB View Post
    Eric, I have a Predator 420 and a 40 series TC for this bike and it does not use a back plate. So the plan is to mount the driven on the end of the jackshaft. I would like to center up the motor as much as possible so that it is comfortable to ride. I am not to worried about chain alignment as I can flip the wheel and run it that way if I have to. What I am hoping to do is run a short jackshaft with the driven on the outside and then a sprocket on the inside of the mount so that I can run the chain down the left side like it came.
    I am open on this as I just ordered the JS from OMB today and have not test fit anything except setting the motor in the frame and holding the driven up behind it to see what it would look like.
    Thoughts????
    Thanks,
    Doug
  7. #5
    Member
    Join Date
    Nov 2016
    Location
    Delphos, Oh
    Posts
    89
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I would be hesitant to use a "short" jack shaft. The distance between the driven and the sprocket may not be much, but I would make the distance between the bearings on the shaft, far apart as I could to take the load better. It would also be easier to get it straight and square.
  8. Thanks FOMOGO thanked for this post
  9. #6
    Senior Member FirePowerMinis's Avatar
    Join Date
    Oct 2012
    Location
    Flint, MI
    Posts
    625
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    You can still spread the bearings out as wide as possible, even with driven and sprocket both cantilevered beyond left bearing.
  10. Thanks FOMOGO thanked for this post
  11. #7
    Havasu Dave's Avatar
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    7,289
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Have to agree with Pap and Firepowerminis on spreading out the load. Especially with that much engine. On the Powells, the earlier versions with a BS 5 FH used a short shaft and bearing arrangement for the belt driven and the chain sprocket. However the later models had the shaft quite a bit longer, going through both frame supports. Nine inches in length on 1/2" bolt for the JS.
    Simply weld in a frame fitment on the other side to accept a bearing and the other end of the JS. As far as alignment, well Doug, you've got it on a jig, so you're ahead of where I've ever been on aligning the JS and rear wheel axle for true.
    What has always saved my bacon, is to incorporate easy removal of JS and componets- cut in a C clip groove on the shaft for instance and forego allen set screws. This allows some "wobble" room, and prevents the allens from marring the shaft, making it difficult to slide out of the bearings without sandpaper each time. The other aspect that has saved my butt is having fore and aft adjustment. You will always have the side-to-side because of the JS.
    The final test for me is to install the chain and spin everything by hand. Listen to the chain, and watch how and where it seats on the sprocket. The chain never lies, provided the engine plate is stout. I know, low tech stuff, LOL. You got this.
  12. Thanks FOMOGO thanked for this post
  13. #8
    Dr. Shop Teacher's Avatar
    Join Date
    Feb 2015
    Location
    Falmouth, Virginia
    Posts
    2,483
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The advice you gotten above from Pap, Firepower and Dave is excellent. Take a look at this thread: Gilson Restomod
    Adam did an excellent job describing what he did to make the plates for his jackshaft (and I used his descriptors for my Gilson build). Gilsons have a mounting tab on either side of the frame and a separate plate. Adam shows this and would help you visualize what Dave was suggesting above.
    Wilderness~Copperhead~Trail Bike
  14. Thanks FOMOGO thanked for this post
  15. #9
    FOMOGO's Avatar
    Join Date
    Jan 2016
    Location
    Upstate, SC
    Posts
    578
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by PAP View Post
    I agree and by short I was referring to the fact that the assembly would be stacked with the driven, then the JS bearing and then the gear with another bearing on the other side of the frame. I didn't make myself clear. But thank you for pointing it out just incase I was going to do it the way it sounds. Because it does sound bad..... As in fail on the first ride.
    Quote Originally Posted by FirePowerMinis View Post
    That is my original intent.
    Quote Originally Posted by Havasu Dave View Post
    Thank you Dave. I like the C-clip deal. That could save a lot of headaches... And you make a good point with the fact that the chain never lies..... And the engine plate is 1/4 inch..... Stouter than the bike its self...
    Quote Originally Posted by Dr. Shop Teacher View Post
    Thanks for the link. I will read it and study what I need to do. While I wait on my OMB delivery of my new JS...
    The bike has an adjustable axle so I am thinking that if I get the axle all the way to the front or rear end of the slot and work square to that I should be square to the bike. I hope to bolt the engine down with just 4 holes if I can get my centerline distance correct for the belt length, which I haven't bought yet. I figure at the worst I can slot the engine bolt holes for a little fudge factor. I am hoping and intending to weld the JS brackets solid without another adjustment point.
    Just waiting on parts...
    Thanks guys for taking the time to reply.
    Doug
  16. #10
    Join Date
    Apr 2014
    Location
    MA
    Posts
    2,260
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I only have 1 bike with a jackshaft and my setup likely won't be of much help to you I'm afraid. I use a JR dragster style jackshaft plate with a Polar clutch. The Polars need to have a certain offset for the driven and also certain spacing for the belt. I used a straight piece of square stock on both sides, the belt side and the sprocket side, to align everything. Like was said, chain doesn't lie and I was able to get it very smooth and straight.
    Here is a pic of my setup
  17. Thanks FOMOGO thanked for this post
Similar Threads
  1. Tips and Tricks for Montgomery Ward ZCQ-57091A (T555)
    By JakeWilla145 in forum Strictly US Vintage
    Last Post: 06-24-2014, 10:12 PM
  2. Wheel / rims tips,tricks & IDing
    By JamnJM in forum Mini Bike Discussion
    Last Post: 06-19-2012, 03:09 AM
  3. Tips and tricks?
    By mpeiffer96 in forum Honda / Clone / Predator
    Last Post: 07-14-2011, 05:01 PM
  4. tips and tricks TAKE 2
    By jrzzz315 in forum Projects & Rides
    Last Post: 03-23-2011, 11:44 AM
  5. anyone want to share tips tricks / how tos?
    Last Post: 03-23-2011, 12:48 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
