Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Tecumseh HM100 Engine?
    Looking for an education and/or informative links on the Tecumseh HM100 engine.
    I take it that this engine is not the same as the "Star" engine, or is it? If it is not... What is the difference?
    I just brought home an electric start HM100. The identification # is: 159290M (B) D.O.M. 5026 D
    Looking forward to learning more about this engine.
    Thanks
    ~JM~
  2. #2
    Senior Member milo raptors's Avatar
    Join Date
    Aug 2009
    Location
    somewere nice
    Posts
    1,298
    Rides
    i belive the bore an stroke are the same but the block is diferent
  3. #3
    Banned
    Join Date
    Oct 2006
    Location
    Rockford, IL.
    Posts
    1,737
    Rides
    It's a good base to start with. It's basically a Briggs 5HP, with twice the power. Clearance the rod to .003", remove the governer and parts, port it (Not required), add an air filter adapter and air filter, put a decent pipe on it...and hang on. I've got one in my photos. Check it out. Scott.
  4. #4
    Well... So far, all that I've learned is that I screwed up & did not end up buying a 10HP Star like I thought I was. I do have a very clean (new) engine with what appears to be a good amount of potential.
    Doesn't anyone know of any technical links that describes the differences between the two engines & what types of aftermarket support are available?
    Thank you
  5. #5
    Join Date
    Aug 2009
    Location
    somewere nice
    Posts
    1,298
    Rides
    i belive star parts fit it i think the star just has a befyer block
  6. #6
    Banned
    Join Date
    Oct 2006
    Location
    Rockford, IL.
    Posts
    1,737
    Rides
    The Star weighs about half of what the HM100 does.
  7. #7
    Join Date
    Aug 2009
    Location
    somewere nice
    Posts
    1,298
    Rides
    Quote Originally Posted by badtec View Post
    well i though the star had ribing or webing cast in to the block to strenthing it
    but as far as i know im pretty sure its a stronger block bye the way the one 10 horse of yours is realy nice
  8. #8
    Anyone have any serious tech on either the HM100 or the Star. There has to be something out there that hasn't been destroyed by Google.
  9. #9
    Join Date
    Aug 2009
    Location
    somewere nice
    Posts
    1,298
    Rides
    like we sedthat and the atar are almost the same just a couple diferent castings just imagin a 5 hp briggs with a 2.5 stroke and a 3 inch bore
  10. #10
    Senior Member quiklids's Avatar
    Join Date
    Mar 2009
    Location
    W. Washington
    Posts
    458
    Rides
    Quote Originally Posted by ~JM~ View Post
    Lots of karters used to run Stars...should be some experts to contact on the 4-cycle forum-
    Bob's 4 Cycle Karting- America's largest karting community. karting kart dirt oval racing race bobs 4 cycle forum briggs stratton sprint go
Similar Threads
  1. wanted tecumseh hm100
    By james c in forum Mini Bikes & Parts WANTED
    Last Post: 04-24-2011, 10:08 PM
  2. Tecumseh hm100
    By george3 in forum General MiniBike Talk
    Last Post: 10-04-2009, 01:16 PM
  3. hm100 flywheel torque
    By rimfire in forum Engines and Modifications
    Last Post: 01-17-2009, 09:06 PM
  4. hm100 throttle linkage.
    By rimfire in forum Mini Bikes & Parts WANTED
    Last Post: 01-05-2009, 01:42 PM
  5. HM100 carb
    By minibikes4life in forum Tecumseh Engines
    Last Post: 09-24-2008, 10:11 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
