Register FAQ Members List Calendar Mini Bike Parts Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications > Tecumseh Engines
Reply
Thread Tools Display Modes
Old 02-06-2010, 02:59 AM   #1 (permalink)
Senior Member
Cdrew11's Avatar
6hp Won't start
I have this 6HP Powersport engine that's not starting. The engine has compression and it turns. The spark plug works fine when put on another engine, but when I turn the engine while the spark plug is on the coil from the Tecumseh, I get no spark at all. I've also severed any wired connections from the coil to se if I'd get a spark....nothing. I'm certain the problem is limited to the coil, but I'm not sure how to correct it.
Please reply quickly so I can take advantage of the snow that's falling as I type!
__________________
Bikes don't leak oil, they mark their territory....
~Drew
Cdrew11 is offline   Reply With Quote
Old 02-06-2010, 03:33 AM   #2 (permalink)
Senior Member
im guessing that it dont have points . so that would leave that the coil to flywheel gap could be wrong , should be like a business card off the flywheel . if not the gap then i would say your coil has given all it will give and needs to be replaced .
metal man is offline   Reply With Quote
Old 02-06-2010, 06:00 AM   #3 (permalink)
125ccCrazy's Avatar
make sure you didn't bolt it on backwards or the kill wire contacting any part of the engine and grounding out the coil...
as mentioned above, did you gap it? and is it a non points coil?
125ccCrazy is offline   Reply With Quote
Old 02-06-2010, 01:12 PM   #4 (permalink)
Senior Member
Cdrew11's Avatar
I'm sure it's not backwards. The engine started a 6 months ago, and when I went to check on it now I'm not getting a spark. Also, I've taken off the wiring contacts from the kill switch on the side to see if that was the problem, still, nothing.
__________________
~Drew
Old 02-07-2010, 03:57 AM   #5 (permalink)
Senior Member
check the coil to flywheel air gap. Spec is probably something like .010 - .016 inches. This dimension is critical. IF you make the adjustment and it still does not run or get spark, then the coil is probably bad.
doubletrouble is offline   Reply With Quote
Reply
Lower Navigation
Tags
start, won't
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Where to start? Cdrew11 Tecumseh Engines 5 08-14-2009 01:54 AM
Won't start?? baja carbon Baja Motorsports - Doodlebug MiniBikes 27 04-22-2009 06:22 PM
DB won't start joeyjmeyer Baja Motorsports - Doodlebug MiniBikes 3 12-21-2008 11:23 AM
where do i start? scytzoh General MiniBike Talk 10 10-05-2008 08:40 AM
I'll start. Twisted Minis Shop Tools 6 07-16-2007 02:02 PM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0 RC2 Copyright 2006-2009 OldMiniBikes.com / OMB Group LLC
no new posts
