Results 1 to 5 of 5
  1. #1
    shoe's Avatar
    Join Date
    Oct 2006
    Location
    Mansfield , Ohio
    Posts
    1,103
    Rides
    Tecumseh 2 stroke engine Snowblower
    Anyone ever try to use one of these in a minibike ? they seem to 4 or 5 hp these days and all over Craigs list ,, since I dont have one is the crank size right ? Enough Torque to pull around a mini ? Just asking ?
  2. #2
    Senior Member The Restore Kid's Avatar
    Join Date
    Jul 2007
    Location
    Michigan
    Posts
    11,695
    Rides
    Quote Originally Posted by shoe View Post
    I did... just before I built the Suicycle, I still had the Tomos with 1/2 the engine missing. I rigged one of those Tecumseh 3 horse snow blower motors on it that has the clutch already on it.. I ran a jack shaft and geared it for around 30 at 7,000 I was guessing. two stroke and all.. It worked pretty great I guess.. The carb never was quite right.. It was screwy I think.. But yeah it worked fine. They aren't the best motor in the world and they don't really rev over about 6,500 I don't think but yeah they work about like you'd expect a 3 horse 2 stroke cheapy Tecumseh snow flipper motor would be capable of.. They work pretty great for 25 bucks with a clutch already on them and running motor we'll say..
  3. #3
    Senior Member Oldschool's Avatar
    Join Date
    Aug 2009
    Location
    Clusterhahahahaistan
    Posts
    2,740
    Rides
    That engine came from the UNIBLOCK family ( itself a decendnetd of another common tech 2 stroke developed by Lauson power products. Thats engine has an intersting history since it almost because an air cooled 3 cylinder marine engine Untill Tech bought them out and ruined the company. The 3 cylinder version was hidden in the old Lauson Engineering building attic for almost 50 years and forgotten untill Tech went tits up and the demo guys found it lucky it was saved ).
    There is a high compression head used on the ICE AUGER version.
    There is a read plate from the lawnmower version you can add and run 2 carb.
    The rod is the weak point in the engine. Too bad no one made a Billet rod and invested somn effort into porting and upgrading these engines. They are dogs compared to a MC but they had some charm and potential not to mention VERY CHEAP...
  4. #4
    Junior Member
    Join Date
    Apr 2011
    Location
    Iowa, USA
    Posts
    Rides
    Older post but had to comment I recently put a tecumseh HSK850 on a pocket bike, and it ROCKS! Goes 40mph and is still pretty quick! Little extra effort in building a engine mount/plate, modifying the carburator to idle/have throttle control, throttle linkage, and exhaust but worth every second spent.
  5. #5
    Senior Member minibikedude's Avatar
    Join Date
    Sep 2007
    Location
    Grand Rapids,Ohio
    Posts
    4,742
    Rides
    Sounds like a neat set up but you should start a new post on your build and put some picture with it.
    FYI,Shoe started this thread and he has past away since this was posted.
Similar Threads
  1. Tecumseh snowblower motor 7/8 shaft
    By balljoint in forum Tecumseh Engines
    Last Post: 11-17-2010, 06:44 PM
  2. Replies: 0
    Last Post: 07-18-2010, 07:10 PM
  3. Replies: 0
    Last Post: 01-10-2010, 03:20 PM
  4. Tecumseh H50 Snowblower Throttle Assembly
    By Ruppster81 in forum Mini Bikes & Parts WANTED
    Last Post: 11-22-2008, 03:03 PM
  5. 4.5hp 2 cycle Tecumseh snowblower engine
    By loneagle in forum Tecumseh Engines
    Last Post: 06-16-2008, 02:16 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
