Results 1 to 8 of 8
  1. #1
    Help with Tecumseh H35 oil leak
    Hi new member here,
    I was given what I believe to be a Trail Horse mini bike yesterday. Missing the throttle cable/handles, spark plug, bad gummy gas, and bad rear tire.
    I cleaned the carb, changed the oil, added a new spark plug and it fired up after a few pulls. After running on the stand i noticed I was getting oil spray out of the governor shaft on the back of the motor. I suspect the crank case breather is stopped up can anyone confirm this? Anyone know where to look?
    Either way, I got the back tire to hold air for about 2 minutes and I took it for a spin around the yard! Man this think is awesome, never had the joy of riding a mini bike, these things are addictive.
  2. #2
    Hello
    Join Date
    Jul 2007
    Location
    Deep East Texas
    Posts
    4,011
    Rides
    It does sound like the crankcase vent is stopped up. It is a little short hose hanging down from the valve cover.(small rectangular cover on block below the intake and exhaust port). There is a pcv valve of sorts there that the hose attaches to.
  3. #3
    I checked the breather cover, and sure enough it was packed with dirt. I have the cover off now, cleaned it out with a wooden pick and got it fairly clean.
    Is the governor shaft usually loose in the case? It seems like a decent amount of play but I'm not sure. I am going to get a carb kit for this engine and some various gaskets and stuff and try to get it running smooth. I have some wobbly sprocket and chain issues and a new rear tire, then I should be good to go.
  4. #4
    Quote Originally Posted by mcanders View Post
    The Gov shaft has a little play.
    Are you sure the oil level is right?
  5. #5
    On a level surface I filled the crankcase with oil until I could see it touching the threads on the fill hole. I do this with all my small engines with this type fill hole. I will need to change the oil (it was very dirty) once more when I get it going, looks like 21oz in the book I have. I will check it once more before the next startup, thanks.
  6. #6
    Senior Member dave dickson's Avatar
    Join Date
    Dec 2007
    Location
    Back in Akron, Ohio
    Posts
    884
    Rides
    21 ozs is more than a quart right?, I believe that the motor in question holds .6 qts, that's 6 tenths of a qt which is a little over a half of a quart from empty.dave
  7. #7
    Senior Member jondan's Avatar
    Join Date
    Sep 2007
    Location
    Central, Ohio
    Posts
    194
    Rides
    32oz = 1qt
  8. #8
    Ok, sounds good. I just had to ask to eliminate the first thing to look for. I would change the oil NOW, I can't stand running an engine with bad oil and you don't know what they used anyway!
    Hopefully the breather cleaning works, I've never seen one "spray" out the gov before.
Similar Threads
  1. To stop a leak?
    By C9H13NO3 in forum Honda / Clone / Predator Engines
    Last Post: 07-02-2010, 06:56 AM
  2. Tecumseh h 70 fuel leak
    By focused-1 in forum General MiniBike Talk
    Last Post: 12-27-2009, 05:47 PM
  3. 3 HP Briggs Oil Leak
    By AllTorque in forum Briggs & Stratton Engines
    Last Post: 08-19-2009, 11:11 PM
  4. Doodle bug OIL Leak
    By kingkoopa39 in forum Doodlebug MiniBikes
    Last Post: 03-29-2009, 07:40 PM
  5. Tec oil leak
    By Wigg273 in forum Engines and Modifications
    Last Post: 09-13-2008, 11:36 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
