Register Members List Calendar Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications > Tecumseh Engines
Reply
Thread Tools Display Modes
Old 08-01-2011, 10:06 PM   #1 (permalink)
Junior Member
honing tecumseh aluminum block
hi im new here just trying to find out if its possible to hone an aluminum bore tecumseh. or is it better to sleeve it . i have the means to do it either way but my friend who's a automotive rebuilder says you cant hone aluminum bores they will wear out prematurely. but the lawn mower guy down the street says it should work. if i take these engines down this far i want the most longevity i can get, any help would be appreciated thanx scott.
scott283 is offline   Reply With Quote
Old 08-01-2011, 10:13 PM   #2 (permalink)
Jeff Clark's Avatar
Hone away its only been done for 50 years on them
Jeff Clark is offline   Reply With Quote
Old 08-03-2011, 12:22 AM   #3 (permalink)
Senior Member
oldfatguy's Avatar
just go easy, you just want to brake the glaze on the cylinder wall so that the ring will seat. I read that most of the problems come from not cleaning the bore real good after honing. If you leave any grit in there it will act like sand paper on the piston. wash it out with soap and water and plenty of paper towels to get all the grit from the hone out.
oldfatguy is offline   Reply With Quote
Old 08-03-2011, 08:44 AM   #4 (permalink)
KustomKartKid's Avatar
Quote:
....so Jeff there is no issue with re-establishing the silicone layer at the top of the honed surface ....like with the old nickasil (sp?) coated cylinders.
I know Sunnen developed a honing process that replaced the old chemical etching process but it's been a while since I messed with that stuff.
I'm guessing the answer is "it's a friggin lawn mower engine just do it "!!!
KustomKartKid is offline   Reply With Quote
Old 08-03-2011, 10:57 AM   #5 (permalink)
Jeff Clark's Avatar
Nikasil coated cylinders are more delicate than the iron bores typically used with Flex-Hones. Nikasil is an electroplated oleophilic nickel matrix silicon carbide coating that allows the use of aluminum cylinder walls without a steel sleeve. This coating reduces friction and wear. Great advantages come with the use of Nikasil on coated aluminum blocks or jugs, one of them is the increased heat removal from the piston, pin and ring assemblies. The other advantage is the tighter tolerances can be achieved. Most Nikasil coatings are 0.0003" to 0.0008". To deglaze and freshen up the bore walls you must use an aluminum oxide material based hone. This softer material works well with the hard walls. Use the hone like described above with the exception of much less rotations. Run the hone for 10-12 rotations in the bore and inspect. If the overall cylinder looks touched then you are done and remove the tool.
Old 08-03-2011, 10:58 AM   #6 (permalink)
Still here...kinda
I've honed a bunch of Tec's and never had a problem.
__________________
Need Rupp Parts!
C9H13NO3 is offline   Reply With Quote
Old 08-03-2011, 07:25 PM   #7 (permalink)
Junior Member
thanks for all replys.
Old 08-03-2011, 07:45 PM   #8 (permalink)
Quote:
that's because you're special
.....welcome back Nate!
Old 08-04-2011, 08:24 AM   #9 (permalink)
Senior Member
zeeman's Avatar
Hey guys. Seems like getting the hone in the bore just right would be critical. Is my drill press sufficient for this task? Any recommendations on what hone to get? I had a local Tecumseh tec. look at my cylinder, and he said it was OK. It does not look OK to me though. Thanks.
zeeman is offline   Reply With Quote
Old 08-04-2011, 09:07 AM   #10 (permalink)
Jeff Clark's Avatar
aluminum oxide hone, if your means are limited use a ball type.
Reply
Lower Navigation
Tags
aluminum, block, honing, tecumseh
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Free H-block Tecumseh for Parts MarksA-C Mini Bike Parts 2 02-21-2011 05:16 PM
Tecumseh H-Block Charging Coil MarksA-C Mini Bikes & Parts WANTED 2 12-19-2010 05:58 PM
Big Block Tecumseh noise DrewDay Tecumseh Engines 3 07-11-2010 08:26 PM
tecumseh short block oldschool71 Tecumseh Engines 7 04-07-2010 06:32 PM
Tecumseh HS40 Block And Cam Needed Ruppster81 Mini Bikes & Parts WANTED 0 06-23-2007 08:36 PM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2 Copyright 2006-2011 OldMiniBikes.com / OMB Group LLC
no new posts
