Register Members List Calendar Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications > Tecumseh Engines
Reply
Thread Tools Display Modes
Old 09-19-2012, 09:57 AM   #21 (permalink)
Member
ADRO's Avatar
Quote:
Originally Posted by buckeye View Post
If you have that primer buld carb, they give folks fits.
I had one that I messed with for weeks and never could get it to idle right. Finally bit the bullet and purchase a adjustable carb. Have never had a issue since.
Thats pretty much same thing thats happening with mine, guess I'll just habe to get a new carb.
What kind of carb are you running now? Is it on a Briggs like mine?
ADRO is offline   Reply With Quote
Old 09-19-2012, 10:04 AM   #22 (permalink)
buckeye's Avatar
No, mine was on a TEC 3.5. And I purchased one of the Oregon Reproduction Tec carbs.
__________________
"What conglomeration of parts is this"???
Neck
buckeye is offline   Reply With Quote
Old 09-20-2012, 07:58 AM   #23 (permalink)
125ccCrazy's Avatar
Quote:
Originally Posted by ADRO View Post
It looks sweet BUT the best price I can find is ~58 bucks!!
Would prefer to spend less than ~40
try this.... 20MM CARBURETOR HONDA CRF50 XR50 CRF XR 50 70 ATV CA04 | eBay
__________________
in some cases it's only original once...in others, unrestored it's a piece of crap forever..
125ccCrazy is offline   Reply With Quote
Old 09-20-2012, 08:43 AM   #24 (permalink)
buckeye's Avatar
Randy, will that work on tec and briggs 5hp without any new manifolds?
__________________
Neck
Old 09-20-2012, 09:51 AM   #25 (permalink)
Member
ADRO's Avatar
Quote:
Originally Posted by 125ccCrazy View Post
Thanks! This will fit my motor without any mods?
I like the price much more than ~60
Old 09-21-2012, 08:25 AM   #26 (permalink)
French model
jimh's Avatar
Those fit. I use a 3/4 washer between the carb and intake for a better seal. Just use a gasket on both sides.,and notch it a little for the screws to clear. you have to set the idle and air,but they work great.
__________________
Uh Bonjour
jimh is offline   Reply With Quote
Old 09-21-2012, 09:59 PM   #27 (permalink)
Junior Member
it is a 5 hp briggs and stratton flathead
joeychristiansen is offline   Reply With Quote
Old 09-25-2012, 01:49 PM   #28 (permalink)
Senior Member
The Restore Kid's Avatar
Yeah thats the old Briggs 5 horse, converted with a lawn mower intake manifold.. I've done it to dozens of them..
The carb is probably not jetted to match your motor...PLUS you have to check and make sure that intake isn't leaking air.. They don't really fit the best without a little work..
If that primer bulb carb is the basic right size, which it probably is, you might be able to just get a different jet, and beat up your idle jet, to make it run good..
The air filter is just half missing.. Any lawn mower repair guy will have a dozen of those in the junk pile.. Give em a dollar or two for the missing outer half and a decent used filter and put it on.. They work pretty great.. Then if the carb does get replaced, most any OTHER adjustable Tecumseh carb, the filter will still fit..
The Restore Kid is offline   Reply With Quote
Old 10-01-2012, 05:09 PM   #29 (permalink)
Member
ADRO's Avatar
Thanks! I did notice that the intake pulled away from the motor and was leaking air, it made the motor run at full load no matter how much throttle I was giving-----then backfire and die out, I thought the motor had blown it was so loud. But I tightened it back down and it ran okay..
I think its about time to pull the trigger on a new carb and run an air filter on it
Reply
Lower Navigation
Tags
5hp, craftsman, motor, sears roper, tecumseh
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
New Member, First mini ever. (pics inside) fruh General MiniBike Talk 15 02-22-2012 04:57 PM
*******New Baja Heat Pics inside****** blkscorpion80 Doodlebug MiniBikes 20 12-04-2010 08:52 PM
My new tires for db rims. pics inside mhornfeck72205 Doodlebug MiniBikes 10 05-13-2010 05:57 PM
Modded 6.5 Clone Pics inside can get better ones oldschoolmbrida Mini Bike Parts 1 01-17-2010 07:18 PM
Carb size identification help...pics inside Flyin_Hawaiian Engines and Modifications 10 09-11-2009 02:50 AM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2 Copyright 2006-2011 OldMiniBikes.com / OMB Group LLC
no new posts
