Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    2,905
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Tecumseh OHH60 - Governor setting
    As you can tell by my previous questions/posts I am new to these engines, and learning alot from the collective knowledge on this forum. This is on a 2 year old 6HP engine: I have NO intention on removing the governor, however I do want to make sure it has the PROPER setting/adjustment. On this engine there are 5 holes (# 1 at the top to # 5 at the bottom) on the governor arm for the spring to hook into.Currently, on my engine the spring is hooked into hole # 1 (the top hole)- Is that the correct hole for optimum performance for the engine used on a mini-bike? I ask because I am having some idling problems and was wondering if the two issues are related?
    Thank you
  2. #2
    Member
    Join Date
    Jan 2011
    Location
    antelope vally california
    Posts
    44
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    mines on the bottom but not my prob the govenor used to kick that arm when the engine would bog down and keep the it runing as low idle as i wanted but i took it out now it wont kick that arm and i have same exact prob as u
  3. #3
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    2,905
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I know the overall function of the governor itself, but what is the purpose/function of these different governor spring settings (holes)?
  4. #4
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    2,905
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks Ogsigh for the reply. can anybody else help me out with the proper governor arm (spring) settings and their function on this engine?
    Thank you
  5. #5
    Senior Member jrzmac's Avatar
    Join Date
    Mar 2008
    Location
    North Jersey
    Posts
    2,722
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    the spring is normally on the 4th hole from the top of the gov. lever.
  6. #6
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    2,905
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks jrzmac for the information!
    Just curious, what is the purpose of the other 4 holes/settings? Does the governor setting (i.e., which hole on the governor arm the spring is in) vary depending on the use of the engine, for example; mini-bike, snowblower, generator, pressure washer, etc.?
  7. #7
    Join Date
    Mar 2008
    Location
    North Jersey
    Posts
    2,722
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I have no idea! one thing for sure is that Tecumsehs are notorious for having way too many holes all over the place!!! and if you have something in the wrong hole, things can get screwed up....i.e. why are there 10 holes on the throttle butterfly??? if you dont have the governor linkage arm in the right hole on the carb, the thing won't run!!!!!
  8. #8
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    2,905
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I moved it down to the #4 hole from the top. I noticed, however, that the spring is now quite loose/slack as it does not have to reach as far. There is no spring tension on the governor arm at all- that does not seem right to me. I suspect that this governor had been monkeyed with by the previous owner, and that might not even be the correct spring on there.
  9. #9
    Join Date
    Mar 2008
    Location
    North Jersey
    Posts
    2,722
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    take the spring off and cut an inch or so off. then reattach. on the 4th hole!
  10. #10
    Senior Member MikeBear's Avatar
    Join Date
    Jul 2010
    Location
    Mid-Michigan
    Posts
    1,472
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by creia View Post
    Thank you
    Here's all the pics on the links: 6 hp tecumseh throttle linkage
Similar Threads
  1. Clutch removal on a Tecumseh OHH60 6 HP
    By creia in forum Mini Bike Discussion
    Last Post: 01-05-2011, 04:53 PM
  2. Tecumseh H50 governor
    By blkscorpion80 in forum Tecumseh
    Last Post: 05-29-2010, 10:00 PM
  3. Tecumseh OHV 6.5 Hop ups? Governor Removal?
    By deezildennis in forum Tecumseh
    Last Post: 08-19-2008, 12:02 AM
  4. tecumseh governor
    By jake in forum Tecumseh
    Last Post: 12-26-2007, 01:21 PM
  5. need a picure of governor hookup OHH60
    By jimh in forum Mini Bike Discussion
    Last Post: 09-23-2007, 10:20 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
