Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 10 of 10
  1. #1
    Junior Member
    Join Date
    Jul 2010
    Location
    new jersey
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Unanswered: 1971 rupp mini bike
    ok, i was in the basement of my grandmothers basement and i came across this mini bike. i would really like to resore it, but it seems like i am going to need a few vintege parts. here are some pics of what iam working with
  2. #2
    minibikedude's Avatar
    Join Date
    Sep 2007
    Location
    Grand Rapids,Ohio
    Posts
    4,749
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Great find, A 1971 Hustler. Looks like it got a diaphragm carburetor on it, I would replace it with a adjustable one with a float bowl from Rupp parts. You can get the correct throttle cable there to. Nice bike. What else does it need.
  3. #3
    Junior Member
    Join Date
    Jul 2010
    Location
    new jersey
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    iam not sure right now, i tried to turn it over but it doesnt seem to want to start, i might need a new spark plug, did this modle need a fuel mixture? or is it ok with straight gas?
  4. #4
    Junior Member
    Join Date
    Jul 2010
    Location
    new jersey
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    wheres the best place to find parts for these bikes??
  5. #5
    Join Date
    Sep 2007
    Location
    Grand Rapids,Ohio
    Posts
    4,749
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Its a four stroke engine no mixing of oil to gas,Check the crankcase for oil, Better yet!, Change it, And put 21 oz. of 30 SAE oil back in to it, in the rear oil plug on the engine. It has been sitting as long as it did the gas in the tank is probably bad and evaporated out of it over time. How clean is the inside of the tank. You may need to clean it up, Check the screen on the petcock and or replace the petcock if necessary. Also those carbs. like that can be a real pain when they have set for a long time, so it may not be working properly.Brandt with Ruppparts.com has a lot of Tecumseh engine parts he also sells on ebay. The spark plug should be a J8C champion, If I remember correctly.
  6. #6
    cheezy1's Avatar
    Join Date
    Nov 2008
    Location
    Michigan
    Posts
    9,465
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Provided Answers: 81
    That is one nice @ss find you have...really sweet condition!
  7. #7
    Junior Member
    Join Date
    Jul 2010
    Location
    new jersey
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    ok so i found out a mouse was living in the exhaust....lost of rice came out, and iam currently cleaning the gas tank, it was nastyyy
  8. #8
    Senior Member will72rupp1's Avatar
    Join Date
    Nov 2009
    Location
    north carolina
    Posts
    908
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    nice bike , if you end up needing points make shore you buy the tecumseh flywheel puller tool , if not you will mess up the crank shaft or the flywheel..
    have you got any offers on it yet, i own a lot of rupp bikes & would love too have it also..
    use some ultra fine steel wool on the chrome. it will look new again.
  9. #9
    Senior Member smallbikes88's Avatar
    Join Date
    Nov 2007
    Location
    garfield hts. ohio
    Posts
    3,679
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    first make sure its getting spark? then check the carb make sure its not all gummed up. use reagular gas.
  10. #10
    Join Date
    Nov 2009
    Location
    north carolina
    Posts
    908
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    hay keep it all original get a carb kit, those carbs work well when they are adjusted right.... they were used on all 1970 rupps
Similar Threads
  1. Replies: 0
    Last Post: 10-13-2009, 06:10 PM
  2. Replies: 0
    Last Post: 09-26-2009, 06:10 PM
  3. Vintage 1971 Rupp Hustler Mini Bike Minibike
    By ebay in forum eBay Mini Bikes
    Last Post: 03-09-2009, 03:50 PM
  4. Vintage 1971 Rupp Hustler Trail Mini Bike
    Last Post: 03-02-2009, 06:41 PM
  5. Replies: 0
    Last Post: 11-30-2008, 10:20 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
