User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
Thread: Yamaha QT50
  1. #1
    Junior Member
    Join Date
    Jul 2017
    Location
    Fort Wayne,
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yamaha QT50
    Anyone familiar with Yamaha QT 50 '79-'84 engine runs 10-15 min. then dies & can't start 'til cools down.
  2. #2
    Senior Member MikeBear's Avatar
    Join Date
    Jul 2010
    Location
    Mid-Michigan
    Posts
    1,492
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Check the Charging Coil under the flywheel, they heat up and stop making connection. Clean and resolder the connections.
  3. #3
    Senior Member FirePowerMinis's Avatar
    Join Date
    Oct 2012
    Location
    Flint, MI
    Posts
    771
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Not that I'm a big fan of the Chinese bits, but new replacement stators are under $15 on the 'Bay
  4. #4
    Member
    Join Date
    Aug 2011
    Location
    Idaho
    Posts
    55
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I have a QT-50 that I eliminated the oiler and mix the fuel 50 to 1 and use the oil tank as a fuel reserve with a shut off valve between the 2 tanks. I recommend you make sure the fuel tank is completely clean of rust and then clean the carburetor multiple times, Replace the fuel lines and eliminate the stock air filter, it restricts the air flow a bunch. I installed a K&N styles air filter for much better flow. Remove the muffler and put it in a fire or your barbecue and heat it up to 700 degrees for an hour and burn all of the oil out of it. My engine ran so rich from the factory that it would not run at all when hot. It would bog down and barely idle if idle at all. After doing all of these items mine ran great and never stalled when hot. It will run 34mph on flat ground and I weigh 185lbs. I have never had a problem with my Stator/charge coil and I don't use a battery.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
