User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Senior Member
    Join Date
    Nov 2010
    Location
    Bay Area
    Posts
    272
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hodaka Ace 100 E Code Motor
    The Hodaka Ace 100 E Code is stamped on the cases only right? All other Hodaka motor parts Top End, Head, Side Cases are interchangeable with the other Hodaka Ace 100 Code motors?
  2. #2
    slywilliez's Avatar
    Join Date
    Nov 2010
    Location
    NE ohio
    Posts
    2,334
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    That is correct.
  3. #3
    Senior Member
    Join Date
    Nov 2010
    Location
    Bay Area
    Posts
    272
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    What is the difference between the ACE 100 & ACE 90 besides topend size? Can you tell the difference between the two of them in their E Code?
  4. #4
    Senior Member
    Join Date
    Jan 2009
    Location
    Eugene Or
    Posts
    267
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Ace 90's have four speed transmission's and a internal coil ( spark plug wire comes out of engine case ).
    Ace 100's are five speed. And have a external coil.
    There are other differences, mounts, air filter, ect. But the coil wire is the first thing I look for.
  5. #5
    Senior Member
    Join Date
    Nov 2010
    Location
    Bay Area
    Posts
    272
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Cool, good to know. Thank you for the information.
  6. #6
    Senior Member
    Join Date
    May 2017
    Location
    arizona
    Posts
    254
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I'm old, don't remember half what I should. Take the following with a dash of salt. Hodaka did not make their own motors. I think they were made by the same company that make Rupp and Chapperal motors. I think I remember other brands that used them too. So these might be other sources for parts. Really pretty solid motors and trannys. About the only that went south on them was the little springs that held the ball bearings on the shifter shaft.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
