User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
Thread: Kohler K340-T
  1. #1
    Junior Member
    Join Date
    Apr 2018
    Location
    Illinois
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Kohler K340-T
    Need help! Have excessive gas dumping into carb after shutting off engine. I rebuilt the diagram and even tried a different carb but same results. The carb is a Tillotson HR model.
  2. #2
    Senior Member The.MiniTard's Avatar
    Join Date
    Nov 2017
    Location
    California
    Posts
    315
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    is there a fuel shutoff on the line to the carb? i dont know anything about tillotsons to presume if the float is stuck
  3. #3
    Havasu Dave's Avatar
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    9,130
    Mentioned
    29 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Your main check valve is leaking. Wear on the ball, or wear on the needle, or inadequate spring tension. (Pop off should be set to 10 PSI with gas) There just isn't any other place that will leak statically.
    I'm more familiar with the HL, but same animal. Without a fuel shut off valve, it's not "if" it will leak, it's "when."
    Diaphragm doesn't have anything to do with that, it just pumps.
  4. #4
    Senior Member Sprocket86's Avatar
    Join Date
    May 2010
    Location
    London, Ontario, Canada
    Posts
    687
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hi there and welcome to the forum.
    Be sure your fuel tank is venting and not building any pressure above atmospheric.
    After riding the vehicle, (you didn't specify) if you open the fuel tank cap, is there a hissing sound present?
  5. #5
    Junior Member
    Join Date
    Apr 2018
    Location
    Illinois
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Sprocket86 View Post
    It will still feed gas into carb right after engine is shut off. I looked at the float valve (fulcrum?) and adjusted to close quicker. Havenít tried it yet but thanks you put me on the right track.
  6. #6
    Junior Member
    Join Date
    May 2018
    Location
    weidman Mi.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    inlet needle lever set to high. or inlet needle leaking.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
