User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
  1. #1
    Junior Member
    Join Date
    Dec 2015
    Location
    michigan
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    minuki mv carb mixture
    I am having a problem getting my Suzuki mt50 to stay running, how many turns out should the mixture screw be? I think it needs a new carb. but I can't find one. I have cleaned it 2 times so I know it's not dirty.
  2. #2
    Join Date
    Dec 2008
    Location
    so calif
    Posts
    472
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    There are 2 screws the large screw moves the throttle slide up and down it sets the air at idle .....the small screw is an air bleed for the throttle mixture very minor adjustment......the main problem with most is a clogged pilot jet its inside remove the float bowl again find the pilot jet use a very small screw driver ....this jet should be clear all the way through its small than a straight pin look for light thru it......see a motorcycle manual for mikuni.....there s lot of replacement carbs out there see ppgmotors
  3. #3
    Junior Member
    Join Date
    Dec 2015
    Location
    michigan
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I can't find a carb for it, I bought a kit for the carb. but it didn't help. I have to block off some of the air filter holes for it to run. I have cleaned the carb twice and made sure all the jets are clear. Is it possible that it has a problem with a valve? it runs to lean, until it warms up good, and it's hard to start because the choke it stuck off and I can't get it freed up.
  4. #4
    Join Date
    Dec 2008
    Location
    so calif
    Posts
    472
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by slow greg View Post
    I still think you have a plugged pilot jet or passage spray carb cleaner then air try to fix the choke assy ......thats pccmotors.com under dirt bike parts there cheap they show a slide on carb but dont give a manifold hole size you could call them also suzuki parts depot shows a spec sheet
Posting Permissions
  • You may not post replies
  • You may not edit your posts
