User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 7 of 7
  1. #1
    Junior Member
    Join Date
    Nov 2017
    Location
    Pennsylvania
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Removing tire from wheel Sperry rand tricart
    What is the best way to dismount a rear tire a good one that holds air from the wheel and split the wheel so I can remove it from the tire.
  2. #2
    Charles S's Avatar
    Join Date
    Mar 2017
    Location
    757
    Posts
    846
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Try asking in the Trikes forum.
    "The difference between stupidity and genius is that genius has its limits." - Albert Einstein
  3. #3
    gumpit's Avatar
    Join Date
    Aug 2009
    Location
    Natick,MASSACHUSETTS
    Posts
    11,363
    Mentioned
    44 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Gumpit
  4. #4
    wildman's Avatar
    Join Date
    Dec 2009
    Location
    Lancaster Co, PA
    Posts
    326
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thereís no magic trick to dismounting these tires. It's just a conventional tire bead and seat. The rims canít be split. They can be messy to dismount because the rims are deep and tires are usually old and dry. The small 6" size doesn't give you a lot of flexibility around the bead. Use lots of bead lube and patience when dismounting and mounting. Iíve used a HF small tire changer on these but needed to make an extension to work with these deep wheels. Often the hard part is getting the wheel off the axle if it's never been off in its life. It usually takes many soakings with liquid penetrant, application of heat or a slide hammerÖ or some combination of all.
    If itís holding air, why dismount it? These tires haven't been in print since the seventies, so if the bead gets wrecked, you're done.
  5. #5
    Junior Member
    Join Date
    Nov 2017
    Location
    Pennsylvania
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thank you I did not want to destroy the wheel I don't care about the tire I thought the wheel was a two piece wheel I got new tires to mount I 'll just cut the tires off
  6. #6
    wildman's Avatar
    Join Date
    Dec 2009
    Location
    Lancaster Co, PA
    Posts
    326
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I'm curious about what tires you found to fit these rims.
  7. #7
    Junior Member
    Join Date
    Nov 2017
    Location
    Pennsylvania
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I got two goodyear terra tire 16x15-6 that my buddy found in an old shop in Calif one had a beadlock wheel mounted in it that said terra-Trac on it.I won't be using them so I'm going to sell the tires and wheels.I'm doing something different on the rear.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
