User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Junior Member
    Join Date
    Jan 2017
    Location
    NY
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    doodlebug foot peg
    Anyone have an extra round rubber foot peg assembly? I need the one that fits the larger diameter pin, probably close to 1/4 inch or slightly bigger. Thanks.
  2. #2
    Member stefano225's Avatar
    Join Date
    Sep 2017
    Location
    willow grove PA
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    https://www.ombwarehouse.com/baja-99...foot-rest.html is that what are you're looking for?
  3. #3
    Junior Member
    Join Date
    Jan 2017
    Location
    NY
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks but they don't have it. Apparently somewhere mid stream the manufacturer changed it. OMB only has the smaller diameter peg/pin. Hoping someone has a spare.
  4. #4
    FOMOGO's Avatar
    Join Date
    Jan 2016
    Location
    Upstate, SC
    Posts
    2,335
    Mentioned
    46 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Can you not just drill the small hole to the size you need?
    "A day without laughter is a day wasted." - Charlie Chaplin
    If stupid could fly you would be a jet.
    Duct tape cant fix stupid but it can muffle the sound.
  5. #5
    Junior Member
    Join Date
    Jan 2017
    Location
    NY
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    It may come to that. I am a little concerned with the length and it not staying rigid with weight on it if the hole is not quite in the right spot.
  6. #6
    FOMOGO's Avatar
    Join Date
    Jan 2016
    Location
    Upstate, SC
    Posts
    2,335
    Mentioned
    46 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The hole is in the right spot it just needs to be enlarged in my opinion. The peg design is sketchy from the start. They are just sheet metal and minimal at that. They will give with use. All the used Warrior pegs that I have are sagging. They look to be the same pegs.
    Doug
Posting Permissions
  • You may not post replies
  • You may not edit your posts
