User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
  1. #1
    Member
    Join Date
    Oct 2014
    Location
    pa.
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    heat / warrior jack shaft system
    is the secondary gear sprocket supposed the slide on the shaft when the nut is tight? my nut was loose, but even when tightened I can move the outer gear around. the inner one that drives the wheel looks like it has a built in key?, and the outer uses a separate key? thanks for everyones help.
  2. #2
    Member
    Join Date
    Oct 2014
    Location
    pa.
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I figured it out it is a single key for both sprockets but was broke in half
  3. #3
    FOMOGO's Avatar
    Join Date
    Jan 2016
    Location
    Upstate, SC
    Posts
    3,228
    Mentioned
    60 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by 400nitro View Post
    DO yourself a favor and put a TAV on it. The original jackshaft system is ok but the TAV is an nice improvement.
    This one has all the needed stuff.
    https://www.ombwarehouse.com/go-kart...-bolt-kit.html
    Or this one is the basic model.
    https://www.ombwarehouse.com/torque-...-3-4-bore.html
    "A day without laughter is a day wasted." - Charlie Chaplin
    If stupid could fly you would be a jet.
    Duct tape cant fix stupid but it can muffle the sound.
  4. #4
    Member
    Join Date
    Oct 2014
    Location
    pa.
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I plan on doing that over the winter. I'm undecided on what brand. I like the gokartsusa model. my jackshaft secondary had too long of a key, and the nut tightened against the key letting the gears slide around.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
