User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Join Date
    Aug 2016
    Location
    White Lake , Michigan
    Posts
    1,272
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If the crank is only 2" long AND you found a clutch with grub screws, you would have to mount it with the sprocket on the outside. That could cause chain alignment issues. The 2" crank May not be long enough to mount it the other way around.
    Instead of a drilling a hole for the screws, you can also grind a small flat area for them to bite into.
    I may even have a 5/8" clutch with grub screws, I'll look later today.
    Danford1
  2. #12
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    3,175
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by KB2ROCKET View Post
    Buy a crank shaft
    Best answer right here^^^.
    Also,
    I doubt that your engine has a "cast cylinder sleeve" as stated by a previous reply. It is most likely a "Koolbore" all-aluminum block, head, and cylinder wall. Are there any numbers on the recoil shroud? If so post them.
    Michael
  3. #13
    Join Date
    Aug 2016
    Location
    Posts
    1,272
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by danford1 View Post
    Danford1
    I checked. I don't have one. Sorry.
    Danford1
  4. #14
    jeep2003's Avatar
    Join Date
    Oct 2006
    Location
    Vestal NY
    Posts
    7,205
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Cutting a keyway isnt that difficult. Give it a try. I think most 5/8" clutches dont have a removable key anyway. It is definately easier on a shaft that doesnt have an engine in the way. I would buy a clutch first then you can see how far you need to go with the keyway. They dont go all the way across so itll save you some work. Keyways dont have to be perfect either. especially if you have a bolt to tighten it down with. Crankshafts also drill and tap very easy so you might consider doing that aswell
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
