User Tag List
Thanks Thanks:  1
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    11,433
    Mentioned
    52 Post(s)
    Tagged
    1 Thread(s)
    Rides
    Quote Originally Posted by Oldschoolcool View Post
    Can the pto shaft be removed?
    The little shaft is the cam shaft and yes you can simply cut it off .
    You can replace the cam with one that does not have the shaft on it but you would have to plug off the hole in the cover or replace the cover itself.
    Lil Indian, Ruttman, DB30, Warrior, lil Bill, EZ Rider, Savage SSC , Powell, BONANZA
  2. #12
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    11,433
    Mentioned
    52 Post(s)
    Tagged
    1 Thread(s)
    Rides
    When you say " Red One " what engine are you referring to ? The one on this end ?
  3. #13
    Member Oldschoolcool's Avatar
    Join Date
    Feb 2017
    Location
    Northwest Ohio
    Posts
    58
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yes, it appeared to have an outline of a briggs logo, but I could be very wrong, the I'd number didn't make sense to me on the briggs and stratton chart
  4. #14
    Join Date
    Aug 2016
    Location
    White Lake , Michigan
    Posts
    1,611
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    When looking at your first picture, the white engine on the left end has a Briggs gas tank. My guess is 5 hp. The other white on in the middle is a 5hp Tecumseh and the red/orange one on the right looks like a 5hp Tecumseh as well.
    You asked if they are worth fixing up for minibikes...... ah, no. They are totally worthless. It is best to call me and I'll come and get rid of them for you free of charge :-)
    Danford1
  5. #15
    Join Date
    Feb 2017
    Location
    Northwest Ohio
    Posts
    58
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Lol!
  6. #16
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    3,448
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    To the OP-
    Please explain what you mean by your statement asking if the engines are "worth fixing up."
    Michael
  7. #17
    Join Date
    Feb 2017
    Location
    Northwest Ohio
    Posts
    58
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Michael, I was not sure if it was feasible to use engines with a pto shaft stick out for use on a minibike, but OND suggested, just chopping it off and use as is.
  8. #18
    Join Date
    Aug 2016
    Location
    Posts
    1,611
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I've chopped them off before and it works out great. The snow blower engine are good candidates for minbikes. Most of them only have a few hours on them. The aren't used in dusty dirty environments and usually never ran hot with the nice cold winter air for cooling.
    All the ones I had still had excellent compression and when inspected, the cylinder wall looked great.
    The shaft is on the end of the cam and it cuts easily with a cutoff wheel, probably even a dremel. If the engine is running it is even faster to cut off. I've never tried it but I guess you could use a hack saw while it is running too.
    Danford1
Posting Permissions
  • You may not post replies
  • You may not edit your posts
