User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: lighting coil
  1. #11
    delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    6,583
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    TheDullCarbide
    My old 1980s 5HP Briggs flathead snowblower said "Made with provisions for lighting, charging, and electric start systems." It didn't come with any of that though.
    common to find that on gilson snowblower in the late 80's
    here is one i purchase in the past that did have the stuff on it.
    the only down fall on them was the recall was spot welded pointing forward.. had to brake the welds and reweld it pointing up.
    lighted coil briggs used on that unit.
  2. #12
    delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    6,583
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    kc57
    The 3hp on My mini trike has a lighting coil.
    hey, any luck on posting numbers on that small block. i would like to look into it.
    thanks.
  3. #13
    delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    6,583
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    ^^^^^bump
  4. #14
    Senior Member
    Join Date
    Jan 2009
    Location
    Eugene Or
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by delray View Post
    kc57
    thanks.
    No sorry . It is in storage about 45 minutes away. And I have not been over there in while.
  5. #15
    delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    6,583
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    ok,when you get a chance...
  6. #16
    Member Cpl2442's Avatar
    Join Date
    Aug 2017
    Location
    West Michigan
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    delray, Have you looked at the chart put out by Briggs?
    http://www4.briggsandstratton.com/mi...ernator_id.pdf
    It gives the general model number that each alternator will go to.... i don't know if covers flatheads
  7. #17
    delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    6,583
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Cpl2442,thanks for posting that. i believe i have seen that in the past. i save it now....
    when kc57 post's is numbers off is newer style small block flathead it will be little easyer to figure things out. i would like to convert it to a lighted coil and it right now has a 120v electric start on it. so i should be able to find a dc motor for it....
  8. #18
    Join Date
    Aug 2017
    Location
    West Michigan
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I'm in the same boat right now with an Intek 206.
    I'm assuming you already have a flywheel with magnets in it? I have a total of 3 inteks that I've accumlated and the last one I've torn into now has a flywheel with a starting gear wheel and magnets on flywheel with a 1.5 amp DC stator inside. I order a stator that should push out 5 amps with the same "small" magnets as Briggs describes them. Will be fun to get it all together and see what it does.
  9. #19
    Senior Member
    Join Date
    Jan 2009
    Location
    Eugene Or
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I had a buddy check the numbers... Model 90102
    Type 0015-01
    Code 960814FA
  10. #20
    delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    6,583
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Rides
    thanks alot kc57, i do appreciate the info......
Posting Permissions
  • You may not post replies
  • You may not edit your posts
