User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: lighting coil
  1. #21
    Senior Member
    Join Date
    Jan 2008
    Location
    homewood junction,pa
    Posts
    319
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The 5hp engine had a lighting coil but you will need the correct block with the bolt bosses under the flywheel,the longer electric start crankshaft,the taller blower housing for electric start,the flywheel with magnets under the where the points would normally go,and the lighting coil itself.
    These parts were mostly used on generators and some parts can be had from snowblower also.
  2. #22
    Senior Member
    Join Date
    Jan 2008
    Location
    Posts
    319
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    One last thing....the 5hp lighting coils were only good for 5 watts.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
