User Tag List
Thanks Thanks:  4
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Junior Member MINI-BIKE-BASHER's Avatar
    Join Date
    Jul 2014
    Location
    levittown
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by joshua. c. View Post
    I would convert the engine back to gas by switching the carb to a one set up for gas, there's no going back on these carbs once its methanol the jets are bilt into the carb and have been drilled to big for gas and there's no fixing that. after that just try running it. the power output of that old flathead may just surprise you. I got a built up one on my bike and its got more power than I can use most of the time.
    Thank you! Those are the encouraging words I was looking for. Any advice on where to buy a carb. I haven't looked yet,but do you have a good source?
  2. #12
    Senior Member Fantic Freddy's Avatar
    Join Date
    Jul 2016
    Location
    Macedonia, Ohio
    Posts
    699
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Check out eBay, they have all price ranges depending on your budget. I have had good luck with them, just use an ethanol protector in your pump gas and you'll be fine. ( I use a product called "Ethanol Shield")
  3. #13
    Join Date
    Jul 2014
    Location
    levittown
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Fantic Freddy View Post
    thank you for the advice. I saw some carbs on there and the price is definitely reasonable. Maybe I'll give it a shot and see what happens.
  4. #14
    Senior Member David wulf's Avatar
    Join Date
    Sep 2011
    Location
    knoxville tn
    Posts
    6,548
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If I were you I'd run a slide carb I have them on two flatty's.
  5. Thanks Harquebus thanked for this post
  6. #15
    Senior Member neo71665's Avatar
    Join Date
    Jul 2016
    Location
    arkansas
    Posts
    925
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yeah ebay or even amazon for the factory style replacement carbs. They are so cheap I don't even bother rebuilding mine anymore and just get a new one. If you don't mind the wait and want super cheap buy one shipped from china. You don't want to wait you can pay the middle man and order one from a US seller. They all come from china tho.
    I'm a fan of the slide carbs also but if you are just wanting to get rid of it I would just put the factory style back on it. Converting it back to run on gas widens the audience you can sell to. The people that want to run alcohol know how to convert it easy enough and you can sell the other carb.
  7. #16
    Join Date
    Jul 2014
    Location
    levittown
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I like those slide carbs as well, but I am not spending that type of money on them unless they are knock off mikuni's. If that is the case then where can I get one at? The one's I have looked at for my predators are around $100.00 and for a carb that seems crazy to me. I just wish I had more interest in this motor. Seeing what you guys have done to them makes me want to build it, but then I think how easy the predator is and I like how I can throw them away if something breaks.
  8. #17
    CarPlayLB's Avatar
    Join Date
    Aug 2012
    Location
    Long Beach, CA
    Posts
    5,884
    Mentioned
    34 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I have a Raptor gas carb I will sell. PM me if your are interested @MINI-BIKE-BASHER
  9. #18
    Senior Member Harquebus's Avatar
    Join Date
    Jun 2009
    Location
    Eastern TN
    Posts
    131
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by MINI-BIKE-BASHER View Post
    I haven't had an issue with a predator yet and I have 5 of them currently and 2 of them are 4+ years old and all of them have stage 1 kits on them and have been ran hard. I guess I'm just lucky. I don't know how to convert the Briggs back to gasoline. I could research it,but I don't really care to.
    But you're in the Briggs forum, so best to make the most of it, right?
    Plus, I was just stating part of the mantra which states that The Almighty Briggs & Stratton engine is King! All hail B&S!!!
  10. #19
    Join Date
    Jul 2014
    Location
    levittown
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    [QUOTE=Harquebus;1141703]But you're in the Briggs forum, so best to make the most of it, right?
    Plus, I was just stating part of the mantra which states that The Almighty Briggs & Stratton engine is King! All hail B&S!!! [/QUOT
    I guess you're right. This post wasn't meant to praise Briggs though, but it has given me a lot of good advice. I don't care what engine it is as long as it runs and is dependable.
  11. #20
    Member
    Join Date
    Oct 2017
    Location
    South Louisiana
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Basher I sent you a PM on here. Yes you can change it back over to gas. Check your Message Mon Ami ~!~! Plus Tard
Posting Permissions
  • You may not post replies
  • You may not edit your posts
