User Tag List
Thanks Thanks:  2
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 7 of 7
  1. #1
    Member Oldschoolcool's Avatar
    Join Date
    Feb 2017
    Location
    Northwest Ohio
    Posts
    68
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Picked this little gem up
    Its a nice 148cc Briggs flathead from a snowblower, model 09a413 0202 e1. Just working out how im going to hook up my throttle. Suggestions welcome.
    Also, I am substituting a Champion J8C wich seems to be working very well. Is this plug ok to run with this engine?
    Thanks!
    Denny
  2. #2
    Member Orson_Yancey's Avatar
    Join Date
    Jun 2009
    Location
    Portsmouth, NH
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Oldschoolcool View Post
    Thanks!
    Denny
    When this is engine was born, it would have come with a Champion J8. Today, Champion J8C is an excellent choice.
  3. #3
    Senior Member delray's Avatar
    Join Date
    Apr 2007
    Location
    wisconsin
    Posts
    7,034
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I like that little engine too. I pickup one couple years ago and the first thing I notes was a 3inch 3/4 keyway crankshaft and it also comes with a aluminum flywheel. if a guy could just get a billet rod for it. that little thing would spin all day with the right mod's done to it.
  4. #4
    Senior Member markus's Avatar
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    11,224
    Mentioned
    84 Post(s)
    Tagged
    1 Thread(s)
    Rides
    Quote Originally Posted by Orson_Yancey View Post
    actually it would have came with a Briggs 802592S which crosses with an RJ19LM
  5. #5
    Havasu Dave's Avatar
    Join Date
    Jul 2012
    Location
    Lake Havasu, AZ
    Posts
    9,130
    Mentioned
    29 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Two quick ways to incorporate throttle Denny that I know if. First is the get that Briggs throttle kit from OMB. https://www.ombwarehouse.com/briggs-throttle-kit.html
    The second is to incorporate a rock guard with a throttle clamp that screws on to the air filter mounting holes on the carburetor. There are many variants of this in the go kart world. That system would require a throttle swivel that sits in the throttle bell crank, such as the GEM 1348. Might require some enlargement of the hole in the bell crank. I've done several like that, and one using the OMB device above. All work well. No Governor of course.
  6. Thanks RobertC, Oldschoolcool thanked for this post
  7. #6
    Join Date
    Jun 2009
    Location
    Portsmouth, NH
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by markus View Post
    O.K. I stand corrected. I remember back in the 1960's and early 1970's we ran Champion J-8's in all Briggs and Tecumseh
    flat heads. I guess that before Briggs and Tecumseh started to market spark plugs.
  8. #7
    Join Date
    Feb 2017
    Location
    Northwest Ohio
    Posts
    68
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I made up my own throttle. I used a spring, a couple of small fender washers for each end of the spring, and a small clevis with a set screw to lock the cable in place. No govener.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
