User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Senior Member
    Join Date
    Mar 2012
    Location
    Wyoming Mi
    Posts
    1,427
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Got your PM, I'll get things moving on my end..............Tom.
  2. #12
    Junior Member JTalmage's Avatar
    Join Date
    Jan 2017
    Location
    Sardinia, Ohio
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Got your PM, thanks, replied. Don't think that one is going to work for me. Thank you though.
  3. #13
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    3,491
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by JTalmage View Post
    What is wrong with it?
    Michael
  4. #14
    Senior Member
    Join Date
    Mar 2012
    Location
    Wyoming Mi
    Posts
    1,427
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    It's out of an older non roller bearing engine, I could send the side cover with it if it will work, he said he had a newer Briggs, I'm not sure what changes took place in crank design over the years other than roller bearing in the side cover.................Tom.
  5. #15
    Senior Member Harquebus's Avatar
    Join Date
    Jun 2009
    Location
    Eastern TN
    Posts
    131
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    A buddy of mine recently dealt with this shorter crankshaft issue on the Briggs 5 horse. He was offered a crank with an add-on section of equal diameter shafting...
    Help with Crank for 5hp Briggs - DIY Go Kart Forum
    I know, it looks and seems "janky" and ghetto-rigged but it looks like a go.
    I recently sold a Baja Warrior I acquired with a Briggs 5 HP on it. I was shocked to learn the crankshaft was also stubby like yours, and the clutch was also reversed with the sprocket portion inward. The clutch bolt just barely made "purchase" with the crank threads. It was not something I wanted to rectify before selling either.
    EDIT: a small portion of the key in the clutch made contact with the keyway on the crankshaft too, so the thing did work and operate but it was not ideal. That crankshaft extension idea at the link would be the perfect solution for everything.
    Just a heads-up and FWIW.
  6. #16
    Senior Member
    Join Date
    Dec 2009
    Location
    north dakota
    Posts
    2,684
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The cranks in Briggs havent changed in a loong time . The points cut is the big one . Just have to match the bearing bushing orball
Posting Permissions
  • You may not post replies
  • You may not edit your posts
