User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Junior Member
    Join Date
    Aug 2016
    Location
    Slatington, PA
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Correct B&S 3HP Engine for a 67 Taco 22
    Wondering if someone can help me out with an engine question. I want to install a period correct 3HP Briggs & Stratton engine in my 67 Taco 22. My question has to do with the engine Model number, should it be a 80202? I haven't been able to locate a 80202 with a 67 Code but I did find a 80302 with the correct 67 Code number. What is the difference between a 80202 and a 80302?
    Thanks
  2. #2
    creia's Avatar
    Join Date
    Jan 2011
    Location
    Duarte, CA
    Posts
    3,375
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Zooming993 View Post
    Thanks
    The third digit refers to the type of carb the engine had. A "2" would be a "Pulsa-Jet"carb that uses a diaphragm (no float bowl) and the carb is mounted directly on top of the fuel tank. A "3" would be a "Flow-Jet" carb with a conventional float bowl that uses a separate fuel tank. A "period -correct" engine for your 1967 Taco would have been Model # 80202.
    Michael
  3. #3
    Junior Member
    Join Date
    Aug 2016
    Location
    Slatington, PA
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Creia,
    Thank you very much for the reply, it was very helpful.
    Quote Originally Posted by creia View Post
    Michael
  4. #4
    Join Date
    Dec 2008
    Location
    so calif
    Posts
    440
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    so the year is in the .....TYPE area?
  5. #5
    Join Date
    Dec 2008
    Location
    so calif
    Posts
    440
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by slow greg View Post
    .................................................. .................................................. .................................................. ................................................al so in the steenstacominibike.com "pick your power plant" it shows a briggs and stratton 4 models..... a 80100 2.5 hp and 80132 with ball bearing PTO.......a 80200 series 3 hp 80202 aluminum alloy and a 80232 with a ball bearing PTO....then a 4hp 100200......and a 5hp 130200 model
  6. #6
    Senior Member markus's Avatar
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    10,472
    Mentioned
    32 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thats just a scan of a generalized article of engines that were currently available at the time and good to use for mini bikes from engine manufactures, so that may not jive with what Taco actually used. They seemed to favor the the ones without mount provisions on the side case covers, like the 80202.
    and its the last set of numbers that have the year built in it....."code" set of numbers
Posting Permissions
  • You may not post replies
  • You may not edit your posts
